On the CPU front you're golden. Game will be overwhelmingly GPU bound for years to come.
Thank you
May as well wait till the 4080ti as I want to play it in UHD and max everything.
At least all the bugs will be gone and it will be cheaper.
By then you're probably going to need a pcie4 compatible motherboard (assuming you don't have one).
PCI4 is not all that from what I've seen.
Yup, like any new game, its all about the GPU, even my Skylake 6700K at 4.5GHZ will be fine, runs all the latest games with my RTX 2080 super just fine, put all your money towards a 3080 not cpu.
No, all 20 series are rtx.Are there non RTX 20x series? I always wondered why people put RTX 2060/70 etc.
would a ryzen 9 3900x at a standard 3.80 GHz be ok ? and replace the 2080 super with the best 3080 ti or whatever ? i have 16 gigs of ram, but could up it to 32 gigs, as i think more games will start to need more shortly, thanks for any help !! i just got a whole new upgrade before the lockdown and i hope i wouldnt have to change again, cheers.
shhhhh, don't use the b-word. If you say it out loud three times in a mirror EastCoast appears......At the moment it won't do much for most, since graphics cards simply don't use all the available bandwidth. I'm just guessing that the 4080ti may have got to the point of actually needing it, which for anyone without an x570 board, means a new board.
Lolshhhhh, don't use the b-word. If you say it out loud three times in a mirror EastCoast appears......![]()
I’ve yet to see a AAA game where you can’t turn them off or tone them down. Same goes for motion blur and film grain effect for me.I hope we can turn off lens flare and chromatic aberration, both are an absolute eye sore.
There are so many settings these days in games that take up performance and imo make the game looks worse, yet people love to have them on because you know, must run it maxed outI hope we can turn off lens flare and chromatic aberration, both are an absolute eye sore.
