- 30 Jul 2012
Unless I get a big gain on 1440p/165fps, then probably not. My card cannot do my monitors specs half the time.
That's not how it works, the tech works below you monitors refresh rate. Over is when v-sync works, if you have that enable as well. For example, it allows me to avoid tearing and whatever else between my monitors 48 - 165 range, i'm always within those ranges.I'm leaning towards AMD tbh, I've always brought AMD / ATI cards, the sole reason being they were what I could afford. Actually might've had a Nvidia card 10-15 years ago, but can't remember the model.
Also, if I'm happy with 50-60 FPS, is there any reason to be concerned about technologies like Free Sync or G-Sync? Don't they basically just allow monitors to have refresh rate over 60 hertz, and therefore display higher FPS?
Maybe useful for competitive play / Esports.
I used Free Sync on my 4K monitor (display port) in the past and didn't notice much difference, and it just caused resolution problems in some gamies like Civ 6.
Tearing can happen below as well, the frame rate range is the freesync range of my monitor. I tested with odyssey last night, turning off freesync caused screen tearing, probably because I was operating around half my native refresh rate.Well anyway, screen tearing can only happen when the GPU renders more FPS than the monitor can display, so if you buy a monitor with 120 hz or above, I think any screen tearing would be negligible on 99% of PCs, especially at high resolutions.
"between my monitors 48 - 165 range" Do you mean that monitors can't operate at a constant refresh rate like 120hz?
AMD Gpu division considers themselves premium now, so at best we'll get similar performance with a 5-10% discount much like the 5700XT.I'll also be getting another nvidia card most likely. I'll keep am open mind to AMD cards, but likely won't be taking that chance of day (or year) 1 driver issues. If the performance and price is leaps better then I'd possibly take a chance, but it would have to be similar performance but at least 30% cheaper. Unreasonable? Probably, but they've not inspired much trust.
Yep, AMD have to deliver at a decent price. Fury X, way crapper than 980ti and same price or more expensive with sweet FA RAM (i.e.2GB less 'wonder' HBM) won't cut it. AMD Need to think 9700Pro/9800 Pro/5870 as examples of how to play it if they want traction in the market. If 5700XT was £350-380 they would be doing it right.AMD Gpu division considers themselves premium now, so at best we'll get similar performance with a 5-10% discount much like the 5700XT.
Nvidia, They're cheaper than AMD, and im not a fan of AMDs new CP, its just got too much crap in it for me now, its just bloatware imo.
This is where they lose customers like me, I don't get a lot of gaming time, so the risk of having to mess around with drivers or waiting for issues to be fixed would only be considered if the raw performance was there and value. I was purely looking at 5700xt cards before I ended up with a 2070s. For all the issues with drivers it felt more sensible paying 15-20% more for nvidia at the time.
