- 7 Jul 2020
Hello, I just want to know if anyone did try ekwb 16mm torque compression fittings and use barrow 16mm metal tubing. Is there any problem in terms of fitting it with ekwb’s? Or does it fit like a glove?
That's exactly what I ended doing my whole system with it and it's tight as a tight thing (as in nicely tight). Yeah suppose each manufactor will be ever so slightly different, strange we both wen the same company thoughHi and welcome to the forums.
I ended up with Barrow fittings and Mizucool tubing (rebranded Barrow tubing I believe).
