First time I have ever had a duff CPU fresh out of the box.
Ryzen 3200g, 2 bent pins along one edge.
Colour me surprised.
never seen a bent pin out of the box though.Bend them bad boys back and jam it in the socketnever seen a bent pin out of the box though.
First time for me as well, hence the surprise.
After doing a quick check on the internetz, it is not an entirely unknown entity.
I normally dont care too much for bent pins, just wack anything out such as a credit card, ruler whatever I have to hand and bend them back, to this day i have never managed to break one but have bent tons back into shape.
never understood the notion about bent pins and unwillingness to bend it back and slot the CPU in. it is almost like a new CPU has to be aethetically correct or something. for me the downtime or inability to complete the build is more important and knowing that if the pins are bend back carefully there is no harm done.
Of course the situation is different if it was a used CPU which can indicate the CPU has been dropped, sat on, pull out of socket by undue force etc etc, which all can potentially point to damages and abuse
I agree with you but these are bent literally to the base of the cpu.
HaHave you tried contacting OcUK and asking them to refund their profit margins?
Put an RMA in with AMD for the cooler, with a picture showing the damage to the cooler and say you’d like to keep the cpu but would like a replacement heat sink if possible.Well... this build is officially CURSED.
I picked up another 3200G....
And the heatsink backplate mount on the mobo has a duff thread on one of the screw holes meaning the heatsink does not hold.
Luckily I had another backplate I could use.
I will see what else goes wrong.
Ah sorry misread.The cooler is fine, it is the mobo backplate the heatsink attaches to which is duff. One of the threads is not proper meaning screws do not hold.
Continuing the cursed theme, the I/O shield... one of the little retaining clips which keep the ports "outwards"... one of them had gone INSIDE the HDMI port. Just enough flex in the shield to bend it back.
After all this... the system does post, I am amazed.
Because it represents two things.never understood the notion about bent pins and unwillingness to bend it back and slot the CPU in. it is almost like a new CPU has to be aethetically correct or something. for me the downtime or inability to complete the build is more important and knowing that if the pins are bend back carefully there is no harm done.
You do realise the entire cpu manufacturing line is fully automated there is no “man handling”. That also goes to the packaging line with minimal human inputs. There is probably a person at the end of the line putting the plastic into the paper box and seal it.Because it represents two things.
1. Mis-handling of the product
2. Damage to the product
You've just spend x hundreds of pounds on a highly complex piece of precision engineering.
If the pins are bent it's been mis-handled in some way. The pins are clear and obvious evidence of mis-handling, but what if there is some other defect that is harder to spot, arising from the same mis-handling?
Frankly, you wouldn't accept a brand new car with a scratch down one side.
Similarly, you shouldn't accept a brand new CPU with bent pins.
And of course - if you damage the product further whilst attempting a repair - you could then end up having to keep it.[/QUOTE
At the end of the day it's not the end user's fault, nor the end user's responsibility to fix. Nor can you assume that the end user will be equipped or confident to make such a fix.You do realise the entire cpu manufacturing line is fully automated there is no “man handling”. That also goes to the packaging line with minimal human inputs. There is probably a person at the end of the line putting the plastic into the paper box and seal it.
where bend pins are rare from new box it can happen during the assembly lien but that’s nothing to say it is damaged.
comparison to a car is a good one. A car not only has to be function but also aesthetically pleasing. So of course if there is a scratch people will want it out. But if your car is a stock car and you are going to race it to wreck it then does a scratch on the body work make a different?! Hell no.
does a CPU need to be aesthetically perfect for it to do its job if it’s function is not affected
