*** New Phanteks Eclipse P500 models ***
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Alongside these awesome new cases from Phanteks they have released a new range of fans:
Phanteks SK120 Black PWM Fan - 120mm @ £7.99 inc VAT
Phanteks SK PWM 120mm fan, Nine blade design, Bundled motherboard D-RGB adapter and splitter cable
Only £7.99 inc VAT.
ORDER NOW
Phanteks SK120 Black DRGB PWM Fan - 120mm @ £12.95 inc VAT
Phanteks SK PWM D-RGB 120mm , Nine blade design, Bundled motherboard D-RGB adapter and splitter cable
Only £12.95 inc VAT.
ORDER NOW
Phanteks SK120 Black DRGB PWM Fan - 120mm Triple Pack @ £34.99 inc VAT
Triple pack of Phanteks SK PWM D-RGB 120mm fans, Nine blade design, Bundled motherboard D-RGB adapter and splitter cable,
Only £34.99 inc VAT.
ORDER NOW
Phanteks SK140 Black PWM Fan - 140mm @ £8.99 inc VAT
Phanteks SK PWM 140mm fan, Nine blade design, Bundled motherboard D-RGB adapter and splitter cable
Only £8.99 inc VAT.
ORDER NOW
Phanteks SK140 Black DRGB PWM Fan - 140mm @ £14.99 inc VAT
Phanteks SK PWM D-RGB 140mm , Nine blade design, Bundled motherboard D-RGB adapter and splitter cable
Only £14.99 inc VAT.
ORDER NOW
Phanteks SK140 Black DRGB PWM Fan - 140mm Triple Pack @ £39.95 inc VAT
Triple pack of Phanteks SK PWM D-RGB 140mm fans, Nine blade design, Bundled motherboard D-RGB adapter and splitter cable
Only £39.95 inc VAT.
ORDER NOW
2 Jul 2016
I quite like some of the cases but im always put off by phanteks cases by the cut out for the power supply. Ruins the look of them IMO
21 May 2018
South Wales
Like the look of this in black... also appears to offer plenty of room for an AIO placement in the top, this is something I've been looking for.
21 Apr 2007
Ok so I think I found the answer the fans bundled with the cases are not PWM they are the 3-pin speed control by voltage variety, you have to order the PWM fans separately if you want them
Caporegime
8 Jan 2004
Rutland
21 May 2018
South Wales
10 Apr 2015
Hungerford, UK, Earth
Review here
https://www.kitguru.net/components/leo-waldock/phanteks-eclipse-p500a-review-a-is-for-air/
Pros:
  • Impressive air flow and cooling.
  • You can install huge amounts of storage or cooling.
  • 1mm Ultra-Fine Performance Mesh front panel looks great.
  • Excellent user manual and accessory pack.
Cons:
  • Eclipse P500A makes no efforts to deaden noise.
  • Case versions of SK fans are 3-pin and not PWM.
  • no fan controller included
  • Phanteks is keen to sell you a great many accessories.
