Looking at getting a plunge saw with track, does anyone on here have experience with the Bosch? Most of my tools are bosch so it makes sense to get one that will all interconnect etc.
The Maffel seems heavily reviewed - The Bosch is designed and manufactured by them but cheaper.I did a lot of research earlier in the year and bought the corded Festool TS55. It just seemed to be the best of the bunch in terms of quality, features, price and blade availability/range. It’s an absolute quality piece of kit.
A lot of my other kit is cordless dewalt but I don’t regret not buying a cordless version of this. The dewalt cordless version was way more expensive and I don’t actually have any flexvolt stuff either.
I didn’t spend a loads on the track though and bought the evolution one for a sensible price.
All of them seemed to have some form of compatibility issue or quality issue. The dewalt for instance uses its own track which is a bit of a downer. The cheap ones seemed to pretty flimsy in certain places like the angle locks or have odd blade sizing.
Have a look on youtube, there are a few plunge saw round ups.
The Maffel was way too rich for me. Are you looking at corded or cordless?The Maffel seems heavily reviewed - The Bosch is designed and manufactured by them but cheaper.
Probably going to stay corded as Bosch don't do a cordless afaik.The Maffel was way too rich for me. Are you looking at corded or cordless?
If you are going corded I wouldn’t be worried about staying ‘on brand’. If cordless then absolutely get the one which matches the rest of your tools of you are invested in a main line brand.
I did consider the Makita but there's not much difference between them and a lot of people say it has a few bug bears...
We bought the Evolution one for internal bits and bobs at work - Seems pretty good to be fair, makes accurate enough mitres in my experience.What's the best mitre saw. I'd ideally like one which can do various cuts and angles so ideally sliding. Is a double bevel a must?
My first project is going to be wooden panelling. Then a log cabin especially the floorboards. Then I'm going to convert the garage and likely do laminate floors in 1 room too.
Whats your budget?
Bosch Glide is absolutely fantastic. The cut is beautiful with the stock blade. The mitre presets feel much more precise less p,at than any of the other mitre saws I looked at the cut size is great bevels on both sides and has good mitre angle width. The foldaway stand is a work of art. Only downside if using inside is dust collection is only adequate not good. This can be modded.
Best piece of kit I own by a country mile.
https://www.axminstertools.com/bosc...-gta-2500-w-legstand-230v-package-deal-717039
Think I got it for less than that from somewhere in London.
@Psycho Sonny pretty much anything by the main brands (De Walt, Makita, Bosch) will be fine at this price point. The capabilities and quality of the saws will be unsurprisingly similar.
I have a lot of makita gear so I'll look at their range. I've always seen them being used on building sites.
Just to go back to a previous question. I wouldn't say double bevel is a must. Or at least not from my opinion. The effort to flip the saw to the other angle is about the same as flipping the wood to get the corresponding cut and runs the risk of things not being fully aligned.
I have this one and i've been happy with it. My only advice would be to swap the blade for something more wood orientated as i get quite a bit of tear out.
https://www.screwfix.com/p/evolutio...single-bevel-sliding-mitre-saw-220-240v/1062x
Problem with Mitre Saws is there seem to be the likes of Evolution/Erbauer at the £200 mark and then it's a huge jump to Dewalt/Makita etc at the £600 mark. There's no midground!
If you're going to be doing wood paneling, what're you planning on using for the long rip cuts? Do you have a circular saw? I'd be tempted to split the budget and get the above Mitre Saw and then also look to pick up a table saw.
EDIT - Updated to add that whatever you get, make sure it's at least a 10" blade. The smaller 216mm blades wouldn't be suitable for some thicker woods.
