Power Tools & General Tools Recommendations & Advice
This makes me question ordering the Evolution to be honest. I’ve been rigidly sticking to Bosch pro for most of my power tools for years now, but took a bit of a gamble with this.
Now considering cancelling the order and spending some more for a Makita
If i was ripping down fence posts or something then the Evolution would be fine.
Bosch, Makita or Dewalt tbh, as i found out buy cheap buy twice.
Yeah, I don’t know how many times I bought a cheap tool over the years, only to buy another, sometimes another before eventually buying my first Bosch pro. The difference was night and day.
I think I’ll return the Evolution upon delivery and order the Makita I was going to get in the first place… it’s almost double the cost, but will likely be double the quality too!
Edit - think I’ll go for the Makita LS0816F/2. Hopefully it’s a step up. Other alternative is the Bosch GCM 800 SJ
Going to echo this - I have an Evolution mitre saw (think it's the Rage 3-S), and while it's great for rough work, as you say there's too much play in the detents for accurate angles. Was originally bought for some fencing, so it was the perfect tool for the job at the time, but since I've been using it for other work I've definitely been noticing where it falls short.
Went for the Bosch in the end. Brand I’ve used for a while and I like. Little smaller in the width of cut, but it should suit what I need it for, and hopefully will be better all around than the Evo… fingers crossed anyway!
I’m looking for a reasonable priced torque screwdriver, I’m trying to convince myself not to take the Ali gamble. Need it to go from 1nm to at least 4nm
I got the dls211zu when my old saw broke and would recommend. I have an evolution table saw though and it’s very good
What're peoples thoughts on a traditional wheelbarrow vs the 4 wheel garden dump truck type things? The Gorilla Cart is likely bullet proof but expensive, so i'm trying to decide whether the cheaper ones would be as well made/long lasting.
General use would be carting soil/rocks around the garden, so i'm thinking the dump truck would be better as it's more stable. The ground is also dry/rocky and the more contact points might make it a lot sturdier.
Is it just a case that they both have their pros/cons and it's worth considering both depending on the job? I'd want a wheelbarrow for cement at some point anyway i think.
A wheelbarrow.
Soil will fall through the cart/trolley
Vevor stuff is actually ok, we've a couple of liner pullers at work, quality is on par with the ones we were buying from the OEM
Yeah. I’ve used them for a pop up gazebo and I bought some stainless steel doors for an outdoor kitchen and was pretty impressed.
Think it’s the winner for me.
We had both
We still have the wheelbarrow
We don't have the "trug"
I have a non-tipping version of the 4-wheel garden truck and I wouldn’t recommend them for sloping and/or uneven surfaces. The tiller steering makes it very easy put the truck way out of balance on slopes and pulling them uphill when loaded is hard work.
Have you tried the wheelbarrows that have 2 wheels at the front? I used a neighbour’s one a while back and it was much more stable that my rather flexy single wheel one.
Cheers guys.
A two wheel wheelbarrow sounds ideal. I would say my ground is relatively flat and level but with rocks/lumps. That’s what mainly put me off the wheelbarrow as filled with rocks can affect balance a lot.
I have had my wheelbarrow since the mid 80's - I bought a farm barrow which at the time was about 40 quid -Last xmas i stripped it - cleaned and painted it -It is good enough to last me out. Solid frame and galvanised bed.
If you do buy a wheelbarrow do not buy the builders ones -They are narrow and handles are straight which makes them unstable with a heavy load.
The farm barrow handles spread out much wider and make it easy to use. It will also go through a standard doorway.
Also the crappy ones with flat metal between the tube and the wheel.. better to get a mate with a welder to replace that with some thicker metal.
Having got a few quotes in for the plastering/skimming of a room and ceiling (plus other walls and ceilings later on) I decided to do it myself. You know what that means? New tool time!
A Makita DSL801ZU:
IQTBdFkJpQkvRpzWikEo0rQfAScAE2dhlR5O4KJZROMAUT8
I've been debating about getting one of these drywall sanders or getting a plasterer in for a while now and decided to go with the former. It's not cheap, but it's a lot cheaper than what a good plasterer would cost plus I don't have to wait for them to be available for this kind of piecemeal work. If I can get to a reasonable finish I'll be happy. Just waiting on some mesh sanding discs and then I can crack on ;).
Not strictly a power tool.. but my trusty DIY leather belt split (over 20 years old).. so I now have a Site elasticated belt for the DIY trousers :D
I also bought myself some Bosch Pro brad point wood drill bits for the guitar wood drilling over the next few days. The old wood bits are blunted/burned or are HSS bits which aren't particularly precise for the accuracy of wood drilling I will need. Not expensive but certainly sharp!
So Ive always liked and had these 12v tools as they are small and light but still very powerful for a home indoor/outdoor diyer... My first screwdriver and drill driver with hammer was Bosch(both brushed versions) and those are still going strong after 23yrs. But my sister has kind of stolen them for outside jobs as I live in the country so theres a lot of stuff outside that need to be kept maintained.. So Ive just bought these 2 which I will be keeping inside,, a 12v Makita screwdriver and this real cute 12v Mekita SDS drill(both brushed versions),, and I might buy the 12v Makita drill driver with hammer aswel for drilling in wood and soft masonry.
Hopefully these will last me another 20+yrs and I recommed the Bosh/Makita 12v tool range for anyone who has problems using heavy tools or for a home diyer as they are much more powerful than they look. BUT DONT BUY the "12v impact screwdriver" as I bought the Bosch version about a yr ago and it was is a lot less powerful than the screwdriver, but I managed to return it.
Screwdriver costed £50 and SDS drill costed £98(both without batteries).. I bought 2 4amp batteries costing £20 each and charger at about £15(non-Makita brand), so total price about £200.
https://i.~ibb.co~/KzKJYpt7/DSCF6648.jpg
