Found some Jack Wolfskin Texapore mid which look nice, are they an alright brand?
Also quite like the look of adidas offering but i suppose they're not a big walking brand:
ADIDAS TERREX AX3 MID GORE-TEX
one of the reviews ive since found has shown some of the material around the side coming apart. makes you wonder if they're a little lacking on quality control.Currently wearing a pair of AX3 daily, first time I've tried the Terrex range. Think I paid £53 on Amazon and for that money they've been pretty good.
First few wears it seemed like the heel collar was quite low and the footbeds quite thick but soon got used to them, the inner lining of the heel has a horizontal stitch through it which has split with me but not bothering me that much yet, soles are pretty hard wearing too.
Those destinations sound like good places to start, should be a nice intro to hill walking without being too committing (depending on where exactly you're going - but I'd suggest most people with an OK fitness level can probably manage a walk of up to 15km and maybe 500m ascent without too much of a problem, depending on conditions, terrain underfoot, etc - will have to work out what's comfortable for you both yourself though, so start off with something you think will be easy and go from there). Catbells in particular is a very popular one!My mrs is always moaning about getting fit but never wants to do normal stuff like go running or to the gym so might take her walking she might like that.
I've found maps for : Catbells / Wansfell pike, Castle Crag, Rosthwaite and Watendlath. They are all classed as easy so should be ok for the beginner.
As for kit i now have walking boots as does the mrs
I have a camelbak that i use for mountain biking that is quite large
I have golf waterproofs but theyre a bit knackered now.
Presume i'm best of with :
First Aid kit
Waterproofs - is it best to get waterproof trousers or just the really lightweight ones that go over normal trousers . I have countless jackets that i could wear
Plenty of food / water
Maps - i have ordered some OS ones for the lake district
Compass - just grab any or is there ones that are recommended?
Phone and power bank
spare socks
Change / cash
That sound alright?
First and foremost, from where are you starting, where will you be staying?My mrs is always moaning about getting fit but never wants to do normal stuff like go running or to the gym so might take her walking she might like that.
First Aid kit
spare socks
Change / cash
That sound alright?
snip.
Also have Grizedale and Whinlatter within distance which have sign posted routes for startingFirst and foremost, from where are you starting, where will you be staying?
Parking anywhere in the Lake District at thjis point in time is "tricky" and there will be loads of camper vans about.
I won't need to stay as they're not to far away, the routes have parking points noted on them so i was going to find them, if not available find the nearest spot.
Catbells - there are a few "scrambly" bits if you are approaching from the North - not too bad but may put off some nervous beginners.
Castle Crag - easy but once again, may scare the "easily scared".
Rostwaite is a village (I believe) rather than a walk as such; it is a good starting point for a number of walks. - It's this one: https://www.nationaltrust.org.uk/borrowdale/trails/rosthwaite-round-fells-tarn-and-beck-walk
Watendlath (from Rosthwaite) is quite a long but perfectly safe uphill slog (again, for any unfit beginner).
You need to think in terms of "circular" walks, ideally that allow for good parking or that are near your base - and I would suggest Keswick as a base. Latrigg is a good starter walk and then go on to High Rigg. Buttermere is an easy walk and is very beautiful. Around Derwentwater, starting from Keswick is a 20Km flat walk. thanks will take a look
As to kit, I think that you may be overdoing what you are carrying:
- Forget waterproof trousers or over-trousers, they really aren't essential at this time of year; just get some decent walking trousers, ideally with removable lower legs - but not tight ones!
- Adequate water is probably more important than food although a "sugar-rush" will always help prior to or during an ascent.
- A 1:25,000 OS map is certainly a good (essential) idea - it will include a code that you can use to access it with a Smartphone - for God's sake keep any compass as far away from a Smartphone as possible! I would also suggest a see-through map bag. thanks i purchased the OS maps and a clear waterproof map holder. I will look out for the code.
- Forget the power bank, just make sure the phone is fully charged before setting out and you will probably not have a signal for much of the time anyhow. Thanks
- I have never carried spare socks, I just invest in decent ones to start with - I do carry a spare T-shirt and I always carry a fleece as well - just in case. i've got some socks on the way, some warm weather ones and ones for the winter (i always get cold feet).
Two final bits of advice:
Incidentally, I take it that you are not camping (in which case things will be different) or "wild camping". Buses are infrequent but a handy way of getting to a start point if you decide to go for a linear walk (e.g. from Rosthwaite, Seatoller or Buttermere. Nope no camping planned at any point this year.
- Spend time studying and as far as possible memorising your route on a map BEFORE setting off. Noted
- Think very carefully about what you are carrying, it will typically be too much (too heavy) and you will probably find that you have still forgotten something really useful - in my case, Factor 50 sun block.
Sounds good, and yeah Keswick and Ambleside are great places to buy outdoor equipment - lots of options. Good idea not to go overboard at the start - if it turns into a regular hobby then worth getting some more high-end kit, but if after a few walks you decide it'll be a much more occasional thing then not really worth blowing hundreds of pounds on all the gear.Thanks Only thing of the list i've not just got is : Hat/Gloves and a shelter. I've got some hats and gloves somewhere abouts and the shelter i'll have a look when i go up into the main lake district area as i'll get an idea of the size and how they fit into the bag. Also treat myself to this : https://www.amazon.co.uk/gp/product/B07B1QHHMN/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 £20 cheaper being in a greenish colour. If we emjoy it and stick out for the summer i'll look into proper winter wear in Autumn time. Get inspired by two couple of Facebook who are doing the wainrights, looks really rewarding. One of them takes there sheepdog with them, my Old English bulldog lays down part way around a walk normally as hes knackered so dont think i';ll be taking him haha
Haha to tired watching that.@JustBen - here you go, a challenge for you and your wife- Ultrarunner Beth Pascall sets fastest women's Bob Graham Round time.
had never heard of cimalp, seems predominately french - are there any reviews of their products .?Fit on the waist is good for me, a little bit more room in the thigh would be good but I have big upper legs and the material does stretch.
I usually use polartec 200 type trousers ... the likes of rab power stretch, lot's of freedom/flexibility, dry quickly if dampCan anyone recommend a good pair of walking trousers? Need something I can walk the dog in, which will protect me a bit from the rain (but don't need full waterproof). Don't want to spend a lot if possible!
all I could see ... which, bizarrely, confirms thigh issue for that brand.
https://www.test-materiel-outdoor.fr/news/220/61/Rockfit-III-CimAlp/d,Sampleb.html
We are regular Lakes visitors, but have never seen the area as busy as it currently is. The parking on and around some of the popular walks is appalling and for the first time I have seen police issuing fixed penalty fines to the worst offenders.
I'm expecting I'll have to set off early to get parked anywhere. There's supposed to be a nice walk near greenodd which will be easy enough to get parked for.We are regular Lakes visitors, but have never seen the area as busy as it currently is. The parking on and around some of the popular walks is appalling and for the first time I have seen police issuing fixed penalty fines to the worst offenders.
