- 7 Nov 2006
Hey folks, I have just build my first server using unraid (still in trial mode) however when trying to get qBittorrent working I can not do it.
I'm having issues with downloading anything in qbittorrent. I've set the directories up as I want but it wont download anything, if I put it back to default it will. So obviously I'm not putting correct download location or there is permissions issue and as Im a first time user of unraid. Can anyone help me out?
Qbittorrent details from docker page:
/data/mnt/user/Torrents/Downloads/
/config/mnt/user/appdata/binhex-qbittorrentvpn
Setting menu inside it defaults to:
/config/qBittorrent/downloads/
I change it to:
Torrents won't download, each one says stalled, set it back to default and away they go no problem. From this can anyone guide me on what I should be putting in the Settings menu?
I've also tried deluge by binhex also to the /Torrents/Downloads/ folder and it works straight off the bat but its a nightmare of software to use. Hate it. Always used qbittorrent on pc for years so I would like to use it also on server.
Thanks in advance.
I change it to:
Thanks in advance.
