Are old PSUs still up the the job today?
It's probably about 13-14 years old, maybe had 3-4 years of daily use then very little for the last decade.
13-14 years old, I wouldn't be risking any hardware you can't afford to lose.
Capacitors go bad regardless of use
While high end for its release time and well built, that's literally antiquated by now design wise, which was outdated already ten years ago.
Long duration (like years) lack of use also degrades capacitors.
Or more precisely aluminum oxide layer breaks down eventually shorting capacitor.
Occasional use can prevent that:
Normal leakage current maintains/rebuilts oxide layer.
Fair enough, thanks for insight! It's in an Antec 900 case, nice big 200mm fan on top. Maybe I can reuse the case at least.
Any hot tips for a modern, very efficient PSU, unlikely to power anything more than 65W CPU and mid range GPU.
personally, i'd still use the psu you have. yes it's old but you aren't going to stress it hard.
10 year old PSU tests:
i'm gonna quote @Journey here:
Oh yeah, the PSU. You can guarantee that in 7 years time or whenever, you decide to upgrade the first thing someone will ask will be how old is your PSU, and then the'll draw in air through their teeth, just like a mechanic would and say, "best replace it just to be safe".
Really depends on the PSU.
A lot of PSU's from the last few years come with warranties in the 7-12 year range and are extremely reliable/well built, they also have a lot of protections built into them to make sure there's no component damage should they fail.
I'd have absolutely no problem running a good quality PSU for the length of its warranty or until it died, if that's 12 years that's how long I would use it unless it no longer met my power requirements.
