9.5Gb installed as of the latest patch![]()
Yeah crazy, I'm sure I recall doing like a 40gb install on PS4.
There's a few story objectives to follow-up on at the moment.This game has changed a load.
I will have to relearn it from the start.
Is there any new objective now from when it came out?
Then there's lots of little bits of lore scattered all over the place with mini stories to unravel.
- The Atlas path that's been in the game for ages (overhauled in the 1.3 Atlas Rises update).
- Investigating the entity known as Artemis (added with the Beyond update).
- Investigating the story behind the underwater crashed freighter.
- The new abandoned/derelict freighters in space that were added with the new Desolation update.
Also, you can get in your spaceship - that offers protection and will recharge your hazard protection as wellWhat am I doing wrong? I started and the planet was 75 degrees, I couldn't find anywhere to avoid the heat so I died eventually.
Edit: Oh nevermind, had to recharge my hazard protection with carbon which is everywhere lol
Yeah I did the same bit yesterday afternoonI've not got to it yet I literally just started, it's like I forgot everything from last time I played. Also, this game really benefits from HDR.
The beginning planet is always a bit of pot luck, sometimes the game chooses to be nice and you're just on a slightly cold or radioactive planet that only gets really bad either at night or during the storms... then other times it throws you onto a planet that's going to murder you within 5 minutes.What am I doing wrong? I started and the planet was 75 degrees, I couldn't find anywhere to avoid the heat so I died eventually.
I’ve been tempted to give this another blast after hearing about how much the game has improved since launch. I didn’t get on with it back then because quite frankly it was gash.
I still found that the case. I'm a total newcomer, tried it on Game Pass for a couple of hours. It seems very much like those sandbox games where you can do what you want but I am not into them. I got to a second planet and was told to look for copper. Found some, mined it but it wasn't enough and I couldn't see any further deposits. Patience wore out and I uninstalled.
You have similar patience to me in other games it seems![]()
I think this is partly due to the Game Pass effect. If something doesn’t grip me pretty much from the start, it gets deleted and I move on to the next game in the list. I use it as a “try before you buy” type of system.
