If they fall enough then i'd love one actually, the reviews are amazing. It'd need to stack up financially though!I see you in a used Taycan in c.5 years time.![]()
I saw an old Porsche 911 with an electric conversion. Did wonder how it drives. It's not like keen do-it-yourself mechanics have access to the level of R&D as the likes of Tesla
https://www.influx.co.uk/cars/electric-911/It's usually parts from a scrapped tesla. So tesla performance without the heavy weight to lug around.
Someone did it with an old Ferrari 308, it only gained something like 9kg and had almost the same range as it did with the v8. So actually, better than a Tesla![]()
A battery is very heavy, bigger and also generates heat. The issue doesn't just 'go away'.
his looks very cool, even has the original manual shifter/box in play. There will surely be a big market in retro EV conversions in years to come. That thing must be a hoot, and actually really usable compared with everything that goes with an ancient ICE.
How am I misrepresenting? Flow rate in a petrol pump is circa 50 litres a minute. Some faster, some slower. 90 seconds is about a fair approximation of the fill time of my car - I've no idea what fraction of cars have a 700 mile range, but mine does. They to tend pump faster on the Continent, too, plus you can clip so the pump so the pumping time is often used for other things like bug cleaning off the screen (Something else we weirdly don't seem to offer at petrol stations here).
I appreciate my usage is perhaps not typical - my use of a car is heavily weighted towards large distance road trips - its how we like to holiday - but the only usage of a car I'm interested in when it comes to making future purchase/rental decisions is my own, for obvious reasons![]()
Meanwhile with an EV someone drives alongside you and charges you on the go and there is absolutely no need to find a spare charging point at the services presumably?
You said the issue goes away, i can promise you it does not and superfast charging relies on keeping batteries cool.Battery can easily be distributed across the whole vehicle, they do generate heat agreed but its easier to cool them whilst being spread out than a great big lump in one place
You are not factoring in driving to the patrol station and back on route. Its not always as simple as just 90 seconds pumping. Take my situation I work across 4 sites and there are zero fuel stations directly between home and any of the sites. So in an ICE I have to factor in driving a short way off my route, possibly queueing up before starting to pump, possibly queuing up to pay if its not pay at the pump and then driving back onto route. Although it’s not common some pumps are very slow and/or cut out so you have to start a few times. What can sometimes be 90 seconds can easily turn into 5 or 10 mins or longer. There are also traffic lights before getting to my local patrol station which again can delay the fueling time.I've got one of the largest fuel tanks, how is it taking people a lot longer to pump fuel?
Ive not seen any OEM spread a battery out either. They are low down under the car to avoid handling problems of 200kg of battery being stuck in the gaps in the bumper, headlining and door bins like you seem to suggest?
For me the difference is worlds apart as neither of those cars would be on my wish list to be honest as i prefer a larger/more luxurious car as a preference. My next car i think i am going to go for a (used!) Porsche Cayenne, but as a Saloon would be an S-Class Merc or 7-Series BMW.
Which EV can i even get which is remotely comparable to those? Really the only usable ones with a decent range are the Model X or Model S. Those things are seriously expensive and seriously struggle to stack up financially. I did run the maths for a Model S (used) vs a similar aged S-Class Merc, and BMW 7-Series, but again due to the high price of the car, the savings take many thousands of miles per year in duty savings to equalise. The maths does work at a high projected mileage, but right now it doesn't at all, and that is inclusive of the generous tax breaks.
Then add in that lets be honest, the Teslas are no where near as nice as the Porsche, BMW, or Merc. You are paying for the drive-train with the Tesla.
And how do you connect the batteries? HV wires which add mass and are pretty dangerous so you want to minimise interface with them. Plus the batteries need cooling so you have more pipes, more fluid etc.
Your phone gets warm with 5W, the heat from 150kW goes somewhere hence the move from indirect (water) to direct (oil) cooling being needed.
No one is building battery packs that are modular as its pointless and very few are aircooled.
I'm hoping more people have your attitude, as it keeps the BEV low/zero tax rate for early adopters locked in for longer, and since you'll only change for convenience that means you'll suck up any increases in taxation be that fuel duty or VED. Happy days![]()
So both myself and my other half can charge at work. My commute is 2 miles each way - hence I usually cycle - and my partner's is 12 miles each way, though she uses our second car sometimes. Both are free so if anything I'd rather not charge at home (though we're with Octopus Agile and sometimes this is very cheap or we actually get paid to charge). I have a charger installed at home and you can see my setup at https://teslamotorsclub.com/tmc/threads/sharing-my-no-driveway-on-street-parking-setup.189161.
I can't always get parked right outside, but I can usually move it to right outside at some point before I need to charge it. My neighbours are all very kind and if one of them is in the space then they used to message and ask if I wanted to swap, or they wouldn't mind if I asked to.
Otherwise public chargers, namely Tesla Superchargers. If I absolutely had to then I live 5 miles from one which is on the M5 junction and would be my exit route to go north or south anyway. So far every where I've travelled to I've been able to charge for free: I'm off camping this weekend and despite the camp site having no mains electricity with showers heated by solar, the owner is letting me use a 3-pin plug at the farm house to charge overnight. Plenty of car parks and other destinations like hotels have free charging too; I drove to Cardiff and back for free, and if I really wanted I could drive to Cabot Circus in Bristol and charge up for free whilst watching a film or shopping or something.
Lets face it most car design is still limited by having to put a relatively fixed shaped item in the car package. An item thats not easy to place since its very heavy, and generates lots of heat and noise. That pretty much goes away with EV, it allows the same footprint to be changed with less restriction. You could easily fit 3 rows in the same footprint of a 5 series. Cars may end up with seating more like a taxi configuration, one seat up front, luggage by the side, 4 seats behind in a far more open configuration
and this whole area being the total footprint of the vehicle, no boot, no engine compartment.
