Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
image uploader
Bought myself a new gravel bike. Had a mountain bike for the last eight years, so fancied something a little faster and lighter. Not brand new, but only had fairly light use.
image uploader
Ha, good spot. I can see the disc calipers on the front... but no disc. I imagine it's the same on the back, but I can't see. Let's hope he's aware before he takes it for a rideI see the handles for the brakes but where's the discs or the rim squeezing pads ?
I'll be interested how you find it, I've got the iOS version and I didn't get on well with the Tonecloud and found it over hyped.
Ha, good spot. I can see the disc calipers on the front... but no disc. I imagine it's the same on the back, but I can't see. Let's hope he's aware before he takes it for a ride![]()
Looks awesome. I love my gravel. That seat is droped though!
Exhaust posts should always be followed up with videosV10 in the M5 shall be singing sweet tunes soon.
@Raymond Lin - lovin' the look of that aged strat (i personally remove the arm) and like the tidy look of that well specced amp (reviews well, from brief look).
How are you finding the amp? I was looking at buying a dedicated laptop and DAW as i thought i might finally dip my toe into BIAS FX or similar (i have never fully embraced this tech - preferring physical hardware as i play for myself and we're quite remote so no worry of disturbing neighbours.)
I'm also intrigued with the twin speaker spec and how this sounds - it seems a lot of oomph packed into a munchkin size unit - and stylish too, which is always a bonus. But, reading the reviews it would seem that the supplied app makes the BIAS FX software redundant - and if it does would make the amp an absolute steal for me. I noticed @Whoop's post (if you have input @Whoop feel free to add your 2 cents) - but my expectations wont be so high as, as mentioned, it's not a tech i've embraced so if it's relatively easy to use, and fun to dabble - it will suit my purposes, perfectly.
Additional: If you don't mind me asking, where did you source yours?
The seat is slammed down quite a bit as that is both comfortable and looking at a load of bike fit videos the correct height for me. A lot of people get physical ailments as a result of their seat being too high...
Question you may be able to answer, with a aluminium frame and a carbon fork, what grease do you use for the headset? Anything special, or just some lithium based stuff?
