- 18 Oct 2002
- The land of milk & beans
Which clay did you use? I've only used BH and it's never had that issue either.
This oneWhich clay did you use? I've only used BH and it's never had that issue either.
That looks more like blu-tack than a clay bar.
wow, I thought my water was hard at almost 300ppm!
I'm on the look out for a wheel cleaner - I know Bilt Hamber Auto Wheels is a favoured choice amongst these forums but I'm on the look out for a cheaper alternative (Because why not?)
I bought some bolt Hamber auto wheels and I have been absolutely gobsmacked by the results. It’s one of those things where you don’t realise how rubbish something is until you try something good, and the wheel cleaner really is. In fact, I’ve been blown away by all their stuff, for how cheap, good and long lasting it is.
While not a new new car, I've got a 2016 focus arriving this week and as it's a nice colour (deep impact blue) I'd like to get it looking as nice as possible. Would it be worth claying it before a two bucket wash and then polish?
I've spoken to elite car care and they think it has reacted with a wax additive in the shampoo I used. It certainly didn't start like this. I'll just try using water next timeThat looks more like blu-tack than a clay bar.
Can someone recommend a trim restorer? Mines looking faded as expected from a 19yo car.
For longer term care: Gtechniq C4 Permanent Trim Restorer
I also use CarPro PERL on top of the above.
