Afternoon folks,
My i7-7700k runs extremely hot. I found that this was mostly due to the stock VCore sitting between 1.35-1.40. I would often peak 95 degree c playing games. I eventually managed to lower the VCore to about 1.25 stable at 4.5, but the temps still creep up into the 80s with my 212 evo. I understand that these temperatures are fine, but I want them lower in order to raise my clocks from 4.5 to 4.8+
I am planning to delid my 7700k to replace the TIM with Thermal Grizzly Conductonaut. I should have everything delivered by next week to first practise on my old 6600k and then move on to my 7700k assuming that everything goes alright.
My first question is regarding the optional step that everybody seems to have some form of different opinion on: Nail polish for nearby components. I am aware that none of the conductonaut should spill over if you use the right amount and spread it out correctly. However, for such a cheap price why not have the added security?
Will this nail polish be fit for purpose? https://www.amazon.co.uk/gp/product/B00UYJGYCK/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
Ingredients can be found here: https://www.rimmellondon.com/en-gb/nails/nail-polishes/60-seconds-super-shine-nail-polish
My second question is regarding the relid stage. I have again seen multiple opinions on this. People say that you need to relid and match the sealant perfectly to how Intel had it, others say you can do small dots in each corner, and others say that you don't have to do any of that at all.
If I go down the route of just leaving the IHS atop the processor (as I quite like the idea of having no glue to ensure a close to perfect contact with the die and IHS), will the pressure from the retention bracket ensure that the IHS does not move and that the liquid metal covering the die also does not move?
This leads me onto my third question. Again, differing opinions everywhere I look. Should I apply the liquid metal TIM replacement to the die or the die and IHS? What are the differences?
