Caporegime
 - 18 Oct 2002
I prefer using MSI afterburner to overclock
Same, but only because Wattman regularly loses my settings just for the LOLs! I like Wattman otherwise
Nice
My card is a bit weird, it won't go high but it'll go low ([email protected]). More than happy with that tbh, fairly cool considering how stuffy it is in here![]()
yeah it is fairly humid now, just out of interest in AMD have you tried the Auto tuning GPU wondering what boost it gave you, mine gave 2135mhz
Same, but only because Wattman regularly loses my settings just for the LOLs! I like Wattman otherwise![]()
No man, but I'll try it at some point this next couple of days and see what it gives me.
 I wanted to reach 2100mhz ingame but might need little more voltage and already gets pretty toasty and my case hasnt got the best airflowI can understand afterburner easier and the little tweaks found it harder to understand in Wattman also couldnt set zero rpm in Wattman with OC or I couldnt find it
Oh yes. Tuning and tinkering with the GPU to get the best out of it. So long until a window or Adrenaline update messes things up again!this is fun
That's my cooler, great piece of kit!Dissection in progress:
Really? Hmm, what kind of temps are you seeing?In AMD software Auto tuning GPU it sets it to 2135mhz ingame its around 2090mhz but with higher temps , I prefer using MSI afterburner to overclock , gonna leave it as it is currently using Afterburner maybe could try squeezing more but dont think its worth it
Thanks mate- case is an o11d (non xl) I picked up for £60 used - cracking deal if I may say so myself. Was missing a rubber feat and motherboard screws which I got from eBay separately. If I had to buy new I would have gone for the XL as its easier to vertical mount and bottom rad+fans with distro plate.
When it's hot inside never use PL level PL at 0.it wasnt stable after trying warzone, its very humid right now which really isnt helping on gpu it tops 80c and junction 110c i can see that dropping about 20c once this warm spell is gone, I currently had it set boost 2085mhz ingame it stays at 2050mhz this is using voltage 1.15v stock is 1.2v, temps 78c and junction 100c pretty sure this will drop quite abit once the warm weather has passed
even on stock the card boost is 2035mhz ingame its around 2044-2050mhz
I dont understand the power limit in MSI Afterburner do I leave it or increase it ?
Thanks
Wow. She's a stunner!here's mine in that case.
Here is what you do.
1.100mv
2100Mhz
Leave Vram at stock speed.
Fan curve should be at the max you can audibly deal with. For me it's 65C. So what I do is a create a idle temp of 35C and just ramp it straight up to 65C beyond 45C. And it's a flat line at 65C. Temps are pretty low for me doing that.
OOps I meant 65% for fan speed not 65C.Thanks I'll try that
So true. from factory these cards are so limited with fan speed so you can actually boost it up a bit until what you are happy with noise wise and enjoy cooler temps.Fan curve should be at the max you can audibly deal with
