I have the titled cpu which I have owned since new (approx Feb 2020).
Am running on an Asus X570 -E motherboard with 2 x 8gb 3600 ram.
I do not overclock and the computer runs smooth and well BUT the base clock is not 38.00 but instead is 37.25 which also results in the fastest single core being limited to just over 4.5.
I am not able to change the multiplier to 38 and am at a bit of a loss as tow to go about recovering the missing speed.
Any one had a similar problem and found a solution?
To add that I run a custom loop. (Max temp has been 67c - usual temps are between late 30's and early 60's )
I have no wish to overclock or run Pbo etc.
Did read that the problem might arise from the board bios and that in time Asus would sort the problem but despite running the latest bios and having updated at least 4 times since purchase the problem remains.
Should I rma the cpu/ the board or both?
Thoughts appreciated
