- 6 Feb 2004
- Norfolk Broads
I'm looking to change the engine oil and filter myself.
I don't really have the facilities to drain the oil (need to jack car up and remove under tray to gain access to sump drain plug). What of course would be easier, is to buy one of these manual pumps, remove the dispstick and pump it out.
I worry that if I pump it out I will be leaving contaminants behind at the bottom of the sump, whereas a drain would (potentially) flush these contaminants out. I suppose they might be pumped out, but you'd never really know. I guess the oil filter should really catch contaminants anyway.
This is something I would do twice yearly.
What are the pro's and con's?
