Met up with JayEmm last month, video finally come out
Who is the fit guy driving it right at the start, I just did a sex wee
GuiltyWho is the fit guy driving it right at the start, I just did a sex wee![]()
Is he using an air cylinder or something to change gear with a trigger on the stearing wheel?
Yeah, will be a pneumatic paddle shifter, you can see the normal lever moving weith each shift. Must be a weirdo leftie using the left button to shift up.
That thing will fly if he can launch it without aiming for the moon or the wall![]()
Jheez that Fiesta is insane! What monster does it have under the bonnet?
E
Just checked the link, EJ20! Sounds great!
Yea, CO2 ram on the shifter as well as a load cell and a barrel position on the gearbox means the ECU takes care of pretty much everything.
It aims a lot less for the moon than it used to, still needs to suspension tweaks to stop it turning right though.
Indeed, its not under the bonnet though
Imagine the time he'd get if he could actually launch a car off the line![]()
What do you mean?
You can sit on a green light for 20 seconds if you want for non-competitive racing. Timing doesn't start until you break the timing beams which need a inch or two of forward movement
Work mate rolled off a couple of 8.9x passes at Pod over the weekend
Easier said than done, all of those things are considerable amounts of time and money to get right.Yep, and if he had a better launch, and didn't bog down, or have to correct steering, he'd have a better time.
Haha, yea.Didn't realise you worked with Chris Todd. I remember when that was running supercharged + turbocharged cvh motor up front
