I have to wonder if the 50% performance per watt is just a median and not a "best case" when it comes to RDNA 2.
High end looks like it'll be 80CU, but maybe clocked down a little with more memory. That should be 30% over a 2080ti
If the RDNA2 cards are as good / better than the Nvidia cards do you have to be obnoxious to buy one? Do they test you before they let you buy one?
It matters a lot whilst there are games that can't run or don't support DLSS, and right now that happens to be pretty every single game bar a handful of exceptions. I'm not against DLSS just that its practical use seems to be a mile away from the hyperbole
True, but hopefully it will catch on or transform somehow, just like Mantle did.
Mantle was laughed at by most especially the anti-AMD marines. It done a nice job for my FX machine, at least it snowballed into better adoption into Vulkan and DX12. Thing is nvidia dont like to share their toys..
Roff, that is not what happened. When mantle took traction MS announced DX12. There was some controversy in which some believed MS was sandbagging DX12 until AMD put forth mantle.It was laughed at because it was inevitable AMD wouldn't put the support behind it to push it into the mainstream and see wider adoption. The folding into Vulkan and the support pushing Vulkan is largely because of... nVidia doing stuff behind the scenes... (I'm not really sure why*). https://developer.nvidia.com/Vulkan
* I'm guessing a lot is motivated by shaping things in their favour.
http://www.extremetech.com/gaming/1...rectx-12-will-imitate-and-destroy-amds-mantleIn fact, as some of you may recall, an AMD executive publicly stated a year ago that there was no “DirectX 12” on the Microsoft roadmap. Microsoft responded to those comments by affirming that it remained committed to evolving the DirectX standard — and then said nothing more on the topic. Then AMD launched Mantle, with significant support from multiple developers and a bevy of games launching this year — and apparently someone at Microsoft decided to pay attention.
Note: Microsoft has not confirmed “DirectX 12” as an actual brand name for the next-generation of DX technology. It’s used here as the most logical version number.
We’ve spoken to several sources with additional information on the topic who have told us that Microsoft’s interest in developing a new API is a recent phenomenon, and that the new DirectX (likely DirectX 12) will substantially duplicate the capabilities of AMD’s Mantle. The two APIs won’t be identical — Microsoft is doing its own implementation — but the end result, for consumers, should be the same: lower CPU overhead and better scaling in modern titles."
The issue was that MS was tight lipped on (now called DX12). It had other plans for the API which originally wasn't part of the new os at the time. And, having said it wouldn't be compatible with Win7 found it's way to Win7 only several years later. Also, some believe that DX12 is a copy-paste job of Mantle.
Basically added features that are duplicated from Mantle into this unnamed API. So, you cannot trust a word MS tells you.
Roff, it does relate. Mantle was fairly new back then. By your own words adaption was picking up. And AMD's relation to Khronos had nothing to do with Nvidia! What kind of brain wash talk is this??? LOLMost of that doesn't even relate to what I said - there was like 3 developers and 5 games that actually used Mantle and most of them dropped it pretty quickly after an initial title due to lack of support... "bevy of games and significant support from multiple developers" doesn't hold up to the reality.
Then there was some behind the scenes stuff that saw Mantle folded into Vulkan - which strangely nVidia had a big hand in.
Roff, it does relate. Mantle was fairly new back then. By your own words adaption was picking up. ANd AMD's relation to Khronos had nothing to do with Nvidia? What kind of brain wash talk is this??? LOL
I have no idea what your going on about at this point.
Nvidia was the reason for mantle now?? Are you serious???
I completely understand what you are doing Roff. You are attempting to down play AMD involvement in Vulkan when they presented mantle to Khronos Group. Trying to up-play Nvidia's second hand involvment in Vulkan after AMD's collaboration with Khornos based on some tin foil theory of yours will get called out.You are the one peddling brain washed nonsense here. Much of what you said isn't even related to what I've posted and purely attempts to deflect from the thrust of what I have said.
If you actually read what I said instead of going straight into AMD defence mode you might actually have an idea as to what I'm going on about here:
I never claimed nVidia was the reason for Mantle. nVidia had a big hand behind the scenes in getting Vulkan up and running including the folding of Mantle into what would become Vulkan (hence the amount of documentation on the nVidia side and why it is no accident the amount of nVidia specific feature extensions to it now that AMD doesn't have support for) - ultimately AMD kind of played into their hands there but Mantle would have died a death otherwise anyway.
It's not that Nvidia doesn't like to share their toys but rather they create these toys to hamper their competition.
Nvidia are the 'do anything to win' company that took over from Intel as the underhanded shysters of the tech industry![]()
Neither Mantle nor Vulkan excluded Nvidia from participating. So there is no magic receipt from Nvidia. It's only nvidia that close source every API they get their hands on. If nvidia had their way they would have locked out AMD from ever using it again. Then lock down the api as their own, a repeat in history for them.
That is what could have happened if Nvidia was that "involved".
Anyhow it was a decent thing and proved you can squeeze much more performance if you get away from the bloat.
