I'm waiting for someone to test an ARCTIC Liquid Freezer II 280 or the 240 version, but 280 would be best of course
I'm also tempted to see if it will be possible to use a GPU that comes with AIO water cooling to mount that on the bottom. With the ARCTIC on the side bracket. But I'm not sure how well that will fit with the tubes not having space between GPU and bottom of the case for rad+fans as well.
Yes that was it. Perhaps not a good idea then. Does anyone know whether a 600w Corsair Sfax powersupply would be good enough for a 3700x and 2070 super?
Thanks McPhee. Can keep a look out for other power supplies now.
First build on OCUK in by @Simon Belmont
Looks really good, really want to build mine, case arrived an hour ago. Seriously considering not bothering in this heat!
I am running 3700x and 2080 together with corsair 600w. No problem at all.Yes that was it. Perhaps not a good idea then. Does anyone know whether a 600w Corsair Sfax powersupply would be good enough for a 3700x and 2070 super?
Distinct lack of pics going on here.
I'm less impressed by this case than I thought I would be.
The front roof 120mm fan doesn't fit with an SFX-L PSU. This leaves a big gap above the PSU, so it could have been mounted even higher giving more room for cables to run out the bottom (as it is, this area is just as tight as in the M1).
The push pin fan mounts add to the thickness. No fan screws are included as an alternative. I had spares, so that was fortunate (PSA: 25mm thick fans don't fit below a 5700 XT Nitro+).
The side panel push pins are weak. I didn't discover this until I finished, but due to how weak they are, you can't route any cables behind the motherboard tray. I've got to redo all of the cabling now
Negativity out of the way, I really like the case. Compared to the M1, it's big and it's heavy. All of the panels are thick and weighty. I like the plethora of cable tie points, and the included velcro cable ties on the PSU shroud. The drive push mounts are a really nice touch. The finished(ish) build looks awesome with the TG panel.
 Might look at a way to secure that too.I start work at 6. Will get some up when I get home.
i've ordered mine today, but since i'm in france, i think i'll have the case next week. i'll update if the arctic fit as soon as possible!I'm waiting for someone to test an ARCTIC Liquid Freezer II 280 or the 240 version, but 280 would be best of course
