Finally joined the fast hz race
30 Jan 2007
PA, USA (Orig UK)
Got myself an 27" Acer Nitro 165hz IPS screen :) Only 1080P, but figured it was worth it over the AOC 144hz non-IPS 1440p screen.
Fastest screen I've had in the past is 75hz I think. An old Iilayma LCD I really liked.
Seems like there is a difference coming from my 60hz HP, but I don't have them side by side.
*note: I settled on a 1080P based screen, because I have an RTX 2060 and pushing frames at 1440p in FPS games a 2060 is not going to hack it. If I had a 2070/5700 or better I would have got the better res screen.
Yup 1080p isnt bad either its still the main used resolution on steam. You can do 4k 165hz also just tick DSR x4 box only, Below the smoothneas needs to go from 30% to 0% and games should all see it as an option now.
You will see in Diablo 3 like me listed your main res at 1080p 165 and below now will show 3840x2160 165hz. If the UI doea not shrink x4, and the game runs on lowish near 140fps you will quickly find it spoils you and clears up everything. In world of tanks i need to see fallen trees, I could spot a squirrel nevermind a tree and thats 1080p. Its more like a zero aliasing oil painting or something it looks nothing like native 1080p lol.
I will admit, I will still don't understand how the adaptive sync is meant to work, or if it is working lol. (Running freesync monitor with RTX 2060).
I will give DSR a try. I have been very vocal in opposition to it as 'not ready' and 'pointless', but I'll give it a try and see if I was wrong.
EDIT: So I selected x4 and 0% smoothness from nvidia UI. Should I also select 3840 res in windows now, or just leave it at 1080? EDIT2: Tried it in Apex Legends, set to 3840... there is minor difference and some textures were missing also.
It depends per game, I set mine in windows yes i click the 3840x2160 option, There are two another says 3840x2160 ,1080p i dont ever select that one. Then i would set it to 4k in Apex.
Apex might be one of those games, The aliasing change with a game like this with no AA should be not small and idk why textures are missing ive not seen it yet. It should look loads sharper, Get rid of all aliasing and make textures better.
Thats all 4k does really, But if the games blurry with TAA or FXAA on, And has loads of post processing its hard to see. In many games for me its night and day in others it works but the ui wont scale. So maybe try again or maybe Apex isnt great. Personally i play Overwatch and its saved the entire game for me. Its flawless really and its an overall image change i would desribe as pixelated to zero pixelation and zero aliasing and since Overwatch has no native AA thats not post processed this is the only option to stop pixelation for me.
