- 10 May 2004
- Sunny Stafford
Had the same, basically the address has changed (pop up bottom right in my case too)
Thanks for confirming
Seems like a wider issue.Had the same, basically the address has changed (pop up bottom right in my case too)
Seems like a wider issue.don't know if it's been mentioned but the direct links to sub-forums return errors (still going to the old url).
Can't insert Images or video with shortcut buttons
Just an update we have rolled back redirection while we investigate the media and like modal stuff (plus many other modal things) We are aware of the issue and trying to resolve it now.
While redirection is off you can use forums.overclockers.co.uk until we resolve this problem.
Or at least it is in chrome. In good old edge its workingA reason obviously worth jettisoning the "if it aint broke" mantraJust out of interest what was the reason for wanting to change away from a sub domain for the forums?
