He says with DLSS and RTX. I assume that is because they have more "RT cores" and "better DLSS".
Probably RT performance tho.
Depends if that is just for RT and not Rasterisation.?
I think that's still great.
Considering there still arent many games that use RTX, Turing owners are more likely to have a high end Turing card for the performance not solely for RTX so even if the RTX performance on the 3XXX cards is high... it will be down to the non RTX general performance that will sell the cards not the RTX.If the 3xxx wipe the floor with Turing in RTX then surely Turing cards wi
Considering there still arent many games that use RTX Turing owners are more likely to have a high end Turing card for the performance not solely for RTX so even if the RTX performance on the 3XXX cards is high... it will be down to the non RTX general performance that will sell the cards not the RTX.
I hear you but I assume he means RTX 2080 Ti vs 3090.The issue is what are the comparing with. For example they could compare the Titan RTX(Turing) with a RTX3060. The RTX3060 probably will be more efficient than an RTX3090!
I give you an example - the GTX460:
https://tpucdn.com/review/zotac-geforce-gtx-460-1-gb/images/perfwatt_1680.gif
It had far better performance/watt than the GTX480 and was not too far behind the ATI GPUs of its era.
The ATI x1900 came out before the 8800gtx and the 8800gtx was a beast of a GPU nothing could touch it for agesI just don't get the idea of pre-ordering when RDNA2 is going to launch soon. I pre-ordered the ATI 1800X according to the rumoured performance. Cancelled when I saw the benchmarks vs the immediately launched GTX 8800 512MB from Nvidia which was quicker.
I then bought the 8800 GTX 512 mb and ATI then launched the 1900X which was by far the best card of the three. This all happened in a 12 weeks or less period or thereabouts iirc. I jumped early then jumped early again and was rewarded with a decent card BUT not at all the best card for the money at the time. Keep your powder dry and don't shoot until you see the white's of Nvidia's and AMD's eyes. Waiting for the dust to settle in 2-3 months seems wise if you've waited (I have for over 3 years).
That's true, I thought I had seen a second fan some time ago. The 3080 looks like one side is flat on the top while the 3090 seems to have fins so must be the second fan under thoseIs there not another fan on the other side?
Yeah they don't look at good as the last FE cards.
Happily go with AMD if they release a 3080 with VRAM. The question is when!
It had a beast of a price and the UltraThe ATI x1900 came out before the 8800gtx and the 8800gtx was a beast of a GPU nothing could touch it for ages
A few of us are thinking ahead tho to next years games and the year after that.We see games "using" loads of VRAM but wouldnt you need to compare a 10gb 3080 to a 20gb 3080 to note any effects?
Yep, got mine due to 1440p upgrade then getting in fs2020 alpha, rtx perf doesn't interest me, minecraft was nice but.... :/Yes. I bought Turing for its raster performance; RTX wasn't relevant.
Also:
Not everyone wants to upgrade every gen.
£499 or less is 3060 pricing.If you're expecting that level of performance for £499 or less, prepare to be disappointed.
about 14 years later and i still got one my 8800gtx water blocks sitting hereIt had a beast of a price and the Ultra![]()
I myself went SLI 7800gtx > x1900xt-x > 8800gtx
If i remember right the 8800gtx was the first DirectX 10 cardYeah 8000 series was a class of its own thanks to shader changes, etc. the older fixed function cards could maybe hang on in some older games but any newer shader model games they faded.
Went 7950GX2 to 8800GT SLI myself.
