- 2 Feb 2010
- Crowmarsh
why what watt psu do you have?
It's a 650w EVGA G2. Good quality psu, but not that high a wattage.
Yes, probably in Q1 2021 though
At four posts per year you're an obvious spammer!
Don't let him in!!!![]()
Proper embedded version of FE airflow diagram.
which hardly if anyone plays?You don't get it do you.
So the cpu takes more of a bashing, one lowers the rez.
I've been here years too and feel like ill never see the MM in my lifetime haha.1 post on Christmas day, 1 post on my birthday, 1 on Nvidia launch day and 1 whenever I feel like.
RTX IO, do we know if it will work at all with Sata based SSD’s, as in principal it can surely still load straight from the drive to the graphics card, or is RTX IO reliant on the pcie bus for it to function?
Depends really on how hot the air gets, the rear fan is closer to the gpu so presumably that's where most of the heat will be. If anything it will generate less heat inside the case than an open air cooler as they dump all the heat into the case, whereas this is ejecting some out the back.
The Intel Core i9 10900K is the best gaming cpu.
Lol i think it should be either amount of post counts and how active you have beenI've been here years too and feel like ill never see the MM in my lifetime haha.
I dont think you understand at all.
Let me make it crystal clear.
Can you show me a benchmark at 1080p that shows a significant improvement in FPS by using an intel vs AMD.
If not then admit there is no noticable improvements and that i its purely down to GPU unless you are using a very very OLD CPU
Any cpu from the last few years is all perfectly fine for gaming at 1080 or above as its gpu dependant
this^It might push the most fps at low resolution but is it the best buy. No pci-e 4 so slower drives and potentially going forward fps as well. At 4k that cpu shows no benefit over AMD zen 2 and it's missing next gen features atm motherboard wise. Zen 2 makes more sense to me even if it's mainly for gaming.
The thing is, they haven't devalued in the real world. There is no immediate competition. Comparing to a yet-to-be physically released product is pointless. Once these release you could argue a 3080 is suddenly worth £200 because the 4080 is coming...I do think the guy who keeps offering £180 for every 2080ti is a troll and needs banning tbh. We all know they have devalued but if a 2080ti is only worth £180 then a 2080 is only worth £130 and a 2070 is only £80 which is ridiculous.
Nvidia has been using a software scheduler for years that can be very taxing on a CPU's single threaded performance. Although it's not clear what approach will be used in Ampere (hardware/software). In light of this it really does behoove you to get the best CPU with the best single threaded performance to avoid oddities in smoothness, etc.which hardly if anyone plays?
It was the question that i rephased and made it clear for you?That was not the question.
You got to be an amd fan boy?
