NVIDIA ‘Ampere’ 8nm Graphics Cards
So just to clear this up cos I can cancel my order for an 850W
my cpu is 3700x, 2 8gb sticks of rgb ram, 1 m2 drive, 2 3'5" drives, and the vega 64 which is going.
My current 650 80gold psu, replace or not lol.
650watt will cover it. Imo it's worth picking up a power reader to plug in to your wall, lot cheaper than a new PSU.
I would have thought they would go for a longer adapter to hide the connection out of site. I'm also surprised that it is split all the way up to the 12 pin connector. Did nobody think this through.
Funnily enough, it's one of the things I don't like about the FE.
That cable system really affects the aesthetics of the card, and not in a good way.
The FE cards are reference. I think most AIB are custom.
It was the waterblock company who made the claim all opening AIB cards were reference. Yes they may have fancy coolers on but they are still Nvidia reference boards if that makes sense,.
Obviously later cards like the EVGA FTW will be custom boards.
There must be different versions, 2x8 and 3x8 pin.
OMG I thought this was a photoshop but its true! The "Gamer Pink" edition
https://www.techpowerup.com/gpu-specs/galax-rtx-3090-ex-gamer-pink-1-click-oc.b7975
which hardly if anyone plays?
I dont think you understand at all.
Let me make it crystal clear.
Can you show me a benchmark at 1080p that shows a significant improvement in FPS by using an intel vs AMD.
If not then admit there is no noticable improvements and that i its purely down to GPU unless you are using a very very OLD CPU
Any cpu from the last few years is all perfectly fine for gaming at 1080 or above as its gpu dependant
Plenty of OC benchmarks here at 1080p. The mem isn't tuned so there's more to gain.
Will my 750w psu power a 3080 ? (super-flower 80 plus gold if that makes any difference) Thinking of upgrading if I don’t need to add anything else
