Hi,
Alpenföhn's next generation CPU cooler builds on the legacy of its predecessors with a striking design and outstanding cooling properties. The Brocken 3 has a cooling capacity of 220W TDP and Five 6mm heatpipes for optimised cooling.
Below are the 3 new options available:
Alpenfohn Brocken 3 CPU Cooler - 140mm @ £42.95 inc VAT https://www.overclockers.co.uk/alpenfohn-brocken-3-cpu-cooler-140mm-hs-05a-al.html
140mm Fan, Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ 2066 / AM2 / AM2+ / AM3 / AM4 / FM1 / FM2
Only £42.95 inc VAT.
ORDER NOW
Alpenfohn Brocken 3 Black Edition CPU cooler Dual Fan Edition - 140mm @ £53.99 inc VAT https://www.overclockers.co.uk/alpe...-cooler-dual-fan-edition-140mm-hs-05c-al.html
Tower cooler in black, Five nickel-plated 6 mm heatpipes, 2x Wing Boost 3 fans with PWM connection, High compatibility with sockets & RAM
Only £53.99 inc VAT.
ORDER NOW
Alpenfohn Brocken 3 White Edition CPU cooler Dual Fan Edition - 140mm @ £53.99 inc VAT https://www.overclockers.co.uk/alpe...-cooler-dual-fan-edition-140mm-hs-05d-al.html
Tower cooler with up to 220W TDP cooling capacity, Five 6mm heatpipes and two PWM 140mm Wing Boost 3 fans included, Compatible with AMD and Intel systems
ORDER NOW
Check out the rest of the Alpenfohn range here
ORDER NOW
ORDER NOW
ORDER NOW
