Caporegime
- 9 Nov 2009
- Planet Earth
It is somewhat baffling that a company like AMD seems to not be able to produce a decent stock cooler. The reason they gave in that interview a while back was blowers offered consistent performance and didn't depend as much on the chassis, whereas axial depended more on the airflow in the case.
All well and good but do they have to be so loud? Can they not make the heat-sink wider to give more surface area for lower fan speeds? That was the big issue with the Radeon vii, it LOOKED good but when you took the card apart the actual surface area wasn't great at all, plus it had massive chunks taken out of it to accommodate the fans, instead of making it wider so the heat-sink could be taller and the fans not taking away from it.
I have no clue - I heard an explanation once,that AIB parters would get annoyed if AMD overshadowed them.
I can wait if AMD gives me a reason to wait. Just launching "something" in 4-6 weeks doesn't cut it. Something could be anything.
Shrugs. People waited 6 months for Fermi,and months for the FX with zero information,so people always wait for Nvidia. In the end if you are really are that desperate to get something because your system is going to go kaput,then get an RTX3080 when its launched.
