I think it might be an AMD singing contest set in a custom Fortnite map.
wouldnt be the worst thing their marketing dept's come out with.
Videocardz does not think it is fully RDNA2 related:
https://videocardz.com/newz/amd-frank-azor-teases-something-to-come-out-tomorrow
Different company mate.
That was ATI actually made decent cards back then.
Is it just me or does anyone else hate this sort of tease. I am on the cusp of spending £650 on your competions product which will mean it will be 2 years at least before I am remotely interested in what you have to offer and the best you can come up with is some boring fortnite tease and a song about tomorrow which may actually not mean tomorrow but the next day.
Some free advice for you AMD. Stop messing about with this pointless and annoying marketing BS. Just tell us you are having a press conference / release on this date at this time, see you then.
This sort of BS that you are doing now just makes me want to buy a 3080 out of spite.
Rant over.
10/1 they say it's news about some news in a weeks time.
if it is another "coming soon" type statement if i was lisa su id fire all the marketing dept, as well as have a long hard think about announcing stuff months in advance and then showing sod all.
Rant over.
It's simply not that hard to issue/leak some slides and numbers. Otherwise it will be simply too late.
If there's a market for 1m of top tier cards worldwide (Total guess) the that number starts dropping really quickly from the 17th
Could it be that AMD are simply a long way from a functioning card ?
I am talking about something bigger.. I am betting that Intel will continue this momentum into the 2021 HPG launch.. these are expected to be enthusiast grade discrete graphic cards
Anyways IPC the only metric that I look at while determining architectural superiority it doesn't matter that it would end up consuming 10 W more.. not that I know about it... things would be clear as more reviews trickle in..but I see this momentum as fairly promising
Intel has beaten AMD a few times in IGPs. The L4 cache version of Broadwell,and Skylake already did so. Intel basically dedicated more die area for those special versions than AMD did,and used the L4 cache to make up for lack of bandwidth.
If you look at the die plans you can see what I mean with Ice Lake and Tiger Lake:
Both Tigerlake and Renoir are similarly sized,and you can see how the Tigerlake SOC has more of the die area dedicated to the GPU.So in that sense,it does have a more powerful GPU,but also less constrained by sharing power with the cores too(4 vs 8).
In Renoir the cores take up more die area than the GPU,and in Tigerlake the cores take less area than the GPU.
For instance the previous generation Zen+ based APUs,had 11 Vega CUs,but Renoir cut it down to 8CUs but clocked it higher. Power and TDP do matter in mobile SOCs though - apparently the Vega part of Renoir can hit nearly 2.7GHZ with enough power and cooling:
https://linustechtips.com/main/topic/1225149-amd-ryzen-7-pro-4750g-review/
Those are tests from MSI,but the SOC does seem to be quite TDP limited.
I did think the same thing!when he says "you're always a day away" I wonder if that's reference to AMD uncanny ability to always show up a day late and a penny short with its graphic card performance
Die size comparisons don't provide a solid basis for comparing architectures.. especially if they are based on different lithographies
Here are few stats making rounds after Intel hosted its annual architecture day in August. These are stats relevant to HPG (its still a guess extrapolated from datacenter products, close enough for me) based on SuperFin. The HPG parts will be fabricated using TSMC 6nm (rumour, well the TSMC bit is a rumor but Intel has publicly acknowledged that HPG will be contracted to external fabbers)
- IGP Vega. 8 CUs (1 CU = 64 ALUs. 1 ALU = 2 FP32 ops per CLK). 1.8 TF @ 1.75 GHz CLK
- Tiger Lake IGP. 96 EUs (1 EU = 8 ALUs. 1 ALU = 2 FP32 ops per CLK). 2 TF FP32 @ 1.35 GHz CLK (Real world performance delta is more than TF delta)
Currently as things stand the 4 tile version is rated at 500W TDP under SuperFIN, but that might change if they move to TSMC. This is the card from a gamers' wild fantasies and I hope they launch it, maybe clock it lower for all I care.
- HPG 1 tile. 512 EUs (RX Vega 64 class). 10 TF FP32 @ 1.3 GHz CLK
- HPG 2 tile. 1024 EUs. 21 TF FP32 @ 1.3 GHz CLK
- HPG 4 tile. 2048 EUs. 42 TF FP32 @ 1.3 GHz CLK
Also note that, above stats are for datacenter products with a good amount of EU silicon reserved for FP64 and matrix MADs, so the FP32 perf for gaming products is expected to be much higher, as they can pack more ALUs per EU. The IGP makes me confident that these stats might actually translate to real world performance as they seem to have reached a respectable level of driver maturity.
But, enough of that, I see the hype train is picking speed![]()
This was an interersting watch. It seems that having ray tracing in the consoles will help AMD on the desktop since the developers will optimise the raytracing render pipe line.
Not sure if it has been posted yet, but it's interesting.
I hope he does this again once RDNA 2 is out.
Breaking news
AMD RDNA2 is set to be announced this year!
