People in a few days wondering they go 3080 or wait for big navi. (This works for both threads)
people who get 3080 should not be worried because its a relatively cheap card and is a monster, end of story.
Its the 3090 owners who will need anti anxiety pills, because the card is so expensive already
I’ve been out of the gpu loop for 6 months, when I left it was looking more like a 1080 in the Xbox perhaps a ti, do you have a source for this so I can educate myself?Xbox has the equivalent of a 2080ti in it and it pulls less than 300 watts for the whole system, if AMD can't push out an 3080 competitor then something is seriously wrong at RTG.
Almost guaranteed there are more stories online saying miners are sweeping up all the stock than there are actual miners sweeping up the stock. With many publications ripping every other publications stories off for hits this is the way.
Unless you're paying next to nothing for electricity or the price of crypto increases significantly, it will take ages to break even.
But if you're worried, on 17th September at 2pm keep mashing F5 and lock in your price and stock by putting an order in. It's not difficult.
Its entirely possible as there are bulk buys going on behind the scenes which is a shame.
Anything is possible in China. No one cares about embargo or NDAs etc - thats why miners are already buying 3080's and why 3080 reviews are going up in China. heck there are even people selling 3080's over the water in Hong Kong over Facebook
Didn't DF say 2080Xbox has the equivalent of a 2080ti in it and it pulls less than 300 watts for the whole system, if AMD can't push out an 3080 competitor then something is seriously wrong at RTG.
Assume you mean 4k Blu-ray here so 8 seasons of game of thrones and what else?!
Didn't DF say 2080![]()
If they are maxed settings then that is pretty decent considering the jump over a 2080Ti and the perf jump with dlss which looks better than native in most cases.
I’d be more concerned about stock levels to be honest.
+1Relatively cheap?
Nearly £700 for a gpu is now classed as relatively cheap?
Well nvidia definitely changed perceptions over the last few generations.
Next week the Xbox will be 3080 performanceDidn't DF say 2080![]()
Do you know if there is a GA100 die?
I've read about it, but they are not clear if NV will use it.
NVidia use it in their pro cards but I don't think they use anything like all the available cores even though it is a bigger chip than GA102.
