- 22 Mar 2017
- Poland
If i have Seasonic TX-750W PRIME TITANIUM PLUS and when i buy Rtx 3090 that 12pin adapter will be with new gpu? I dont have this on my psu
So then you answered your own question no?
I gave you my opinion, but if you desire the 3090 then go for it, it’s good for the economy![]()
rightIts a nice looker for sure just that 12 pin setup... I heard on the video though corsair and alike looking to bring out a 12 pin cable what has not been said what models of PSUs it covers hopefully RM series are covered the fully modular ones.
right?this is what’s got me double taking on the FE. I recently got some custom cables and the FE will completely hide them. I’ve been looking at the Aorus master only because I have other Aorus components, and they have a screen which adds a smidge of justification for the extra cost. Bet it’ll be stupidly loud though
It will come with the founders cards, the AIB cards just have 3 8 pins I think.But that 12pin adapter comes with Rtx, so its not issueright?
That aorus although looks decent the screen etc just makes it all gimmicky to me but your choice dude!
rightBut that 12pin adapter comes with Rtx, so its not issueright?
It's probably my favourite of the partner cards, just can't justify the extra for that wee display.
It's the fins I'm impressed by, normally it's a solid bit of plastic/metal like the 1080's but this is completely new, should run cooler this way I assume.
Apart from messing up your cable tidying … I can't see mine once in place but I still don't like the idea of the ugly 2x8 pin to 12 pin extensionBut that 12pin adapter comes with Rtx, so its not issueright?
3080 looks a beast...........Then sees pic of 3080 next to a 3090......
£800 IF it stays at that price who knows! but i think thats a little steep unless it has a mad factory overclock.
What's the different between the Master and Xtreme? Never purchased a Gigabyte Gpu before so have no idea or is it just the clock speed?master is still currently £749, but as you say that could change at any time.
Ahh master i thought we was on about the Xtreme...master is still currently £749, but as you say that could change at any time.
