Only thing that put my massively off the FE is that power connector placement. I mean WTF.
I've talked myself out of FE cards because of that awful connector positioning and ugly adaptor. There is no clean way that will satisfy my ocd for wiring that thing up!
Founders edition looks like its gonna be crap in vertical positioning in my view, hard to see without testing and every case is different but I don't see how you're not going to drive a heap of hot turbulent air into the middle of your case slowing down flow from the front intake on its way up to the top and rear exhausts.... I'm not sold it works that way at allI think that’s why I’m so torn between the FE and Aorus. I have a vertical mount and recently had new PSU cables, so having the FE I feel will hinder both of those things
https://www.overclockers.co.uk/pny-...dr6x-pci-express-graphics-card-gx-06h-pn.html Is this new to the list or have I just missed it?
Founders edition looks like its gonna be crap in vertical positioning in my view, had to see without testing and every case is different but I don't see how you're not going to drive a heap of hot turbulent air into the middle of your case slowing down flow from the front intake on its way up to the top and rear exhausts.... I'm not sold it works that way at all
I meant the way the card pushes most of the hot air out of it and infront of the cpu cooler (this is a problem if you have a cpu tower cooler) which I will.
I know that gpus push the air upwards in that direction but with the FE it will be pushing most of the heat out of one spot and that spot being right infront of a tower cooler rather than distributed over more space and fans.
Of course if your cpu is water cooled then there is no issue
I don't hate it (read above your quote here). As I said it's just the reason why I would not buy it for me personally. I could be very wrong.
This time around? That was the case last time around and the time after that
I don't remember any FE cards on launch being available to anyone but nvidia. Later maybe, but not on launch.No, Board manufacturers used to see FE cards as well. I can remember Asus putting £50 on the price just for the Asus name.
AMD? nah thanks.Surprised people are that desperate they can't wait another month to see how AMD scared Nvidia so bad. These launch prices most certainly weren't from their own good grace.
Be sensible, if AMD really do rock the boat you'll soon see a 3070ti/3080ti hit the shelf, and it'll make you instantly regret being a day one buyer.
On launch? Interesting. Thanks did not know.The 1080 series did. I have an MSI branded 1080FE.
Seems you was right, my bad in the endI knew it was last time, I just thought the time before they got into retailers too. You sure? Meh my bad then...
Apologies in advance if this has already been asked.
@Gibbo is there any news on evga 3080/3090 ftw3 versions being a available at launch ?
My EVGA 1080 FE card was delivered on the 28th May so I can confirm they were definitely released the same day in the channel as direct from Nvidia.Checked my email order confirmation, which was 2nd June. Google suggests launch was May 27th, so certainly for launch week.
