I've also thought of buying a pair of 2080tis for SLI. Depends which perform best although support for mGPU is fading fast.if the 3090 doesn't perform gonna be gutted a well give me a excuse to buy a cheap 2080ti for some NV link ..
I was also thinking of keeping my 2080ti and buying a second one now there going for cheap pricesI've also thought of buying a pair of 2080tis for SLI. Depends which perform best although support for mGPU is fading fast.
I'm sure they will boost near 2ghz at stock, Pascal and Turing also had conservative stock clocks but would auto an extra 200-300mhz if the cooling is sufficient
I'm not going to oc my 3080, that would make it a 400w furnace
Only one small snag with this.
A RTX 3090 will never run as slow as 1.695Ghz, it will boost far higher just like the Turing cards do.
Some of the AIB cards will go to 500W..................
MS FS2020 doesn't in DX11 but I bet they will support it when DX12 version arrives. £1 says it will, either way unless it does it will be unplayable 4K ultra over NYC with 2080ti SLI and/or 3080 unless something changes fast. 20-35fps with trackir is air sickness inducing. I suspect AMD may have some secret sauce to apply to the problem.I was also thinking of keeping my 2080ti and buying a second one now there going for cheap prices
But i hear MS FS 2020 doesn't support SLI/NV link and that about the only game i play at the moment that i could do with more GPU performance for
So it not really worth me buying a second 2080ti
there are 3090s with clocks over 2000........
Just saw earlier today the gigabyte auros xtrme 3090 was listed on come Chinese etailer with a boost clock over 2000.Any idea which ones?
It's a strange comparison, basically the best clocking 3080 against a throttling 3090.I'm comparing the RTX 3080 @2.1Ghz (and overclocked memory) vs the RTX 3090 at base clocks.
That's because an overclocked RTX 3080 should be far more affordable than the RTX 3090.
The thing I'd like to know is, will any RTX 3080 GPUs be capable of 2.1Ghz factory clocks?
I also found that the RTX 3080 clocked @ 2050 Mhz would be equal (or a tiny bit ahead) of an RTX 3090 @ base clocks, in terms of TF count, pixel rate and texture rate.
I'm just using the info / stats listed on Techpowerup, personally don't see the point in comparing to an overclocked RTX 3090 (we know what would win), the point is to see if a much cheaper overclocked GPU can offer similar performance to an RTX 3090 running at the specified Boost clocks.
1. Yes if you can afford one
2. But - Only if cooling will allow for it (e.g. if you wanna spend even more on a RTX 3090 with a hign end cooler). I heard non reference / custom 3090s are gonna be sold for ~$2000.
I really doubt the temps are gonna be the same as the RTX 2080 TI, as the RTX 3090 has a 100w higher TDP.
I didn't mention the overclocked RTX 3090...
