Poll: *The Official PlayStation (PS5/PS5 Pro) Thread*
Will you be buying a PS5 Pro on release?
  • Yes
    Votes: 53 14.3%
  • No (not at £700 Lol)
    Votes: 213 57.6%
  • No (other)
    Votes: 85 23.0%
  • Pancake
    Votes: 19 5.1%
  • Total voters
    370
A couple of other things to note
1) The PS5 supposedly has Wifi 6, Xbox has Wifi 5 and
2) The PS5 has a USB-C port, Xbox doesn't.
The ports are neither here nor there your going to get no benefit from them at all are you
your going to sit on your sofa with your wireless pad and play
Well if the USB-C port on the PS5 turns out to be 10Gbps and the Xbox USB-A ports are 5Gbps then you could get faster loading from an external SSD which is connected up for the BC games.
Yeah, they're reknowned for the steep learning curve. You just need to realise you're going to die a lot, over and over again. Sooner or later it all clicks together and the game becomes pretty rewarding.
I'll end up getting it I bet, and abandon it most probably.
I got it on the Switch too, as well as PC, I really want to get into it, but I get too frustrated!
IIRC A vs C doesn't matter. You can do the same speeds on A as you can on C, it's just the connector being a different shape.
PS5 Plus Collection games confirmed so far
  • God of War
  • Bloodborne
  • Persona 5
  • Resident Evil 7
  • The Last of Us Remastered
  • Monster Hunter World
  • The Last Guardian
  • Detroit: Become Human
  • Batman: Arkham Knight
  • Battlefield 1
  • Mortal Kombat X
  • Days Gone
  • Final Fantasy XV
  • Fallout 4
  • Uncharted 4: A Thief's End
  • Ratchet & Clank
  • Until Dawn
  • Infamous: Second Son
Basically most of these games have been on PS plus before. Are they going to keep them there this time!?!?! Hasn't been confirmed yet.
Some of the games clearly won't come to some regions if you see the red box I highlighted.
Eh, have they not said what size drive is coming with the digital version. Curious seeing as the disk version is near 170gb short of a tb.
Just some points to note.
Ports
USB Type-A port (Hi-Speed USB)USB Type-A port (Super-Speed USB 10Gbps) x2
USB Type-C® port (Super-Speed USB 10Gbps)
WiFi
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T)IEEE 802.11 a/b/g/n/ac/axBluetooth® 5.1
Dimensions
PS5: Approx. 390mm x 104mm x 260mm (width x height x depth)(excludes largest projection, excludes Base)PS5 Digital Edition: Approx. 390mm x 92mm x 260mm (width x height x depth)(excludes largest projection, excludes Base)
I know some were worried about size, my typical oak tv unit has 450mm of space width wise so a little extra room.. not sure on the excludes largest projection bit.
