Not sure where they would put them on the back![]()
Probably a slightly different pcb for it, the cards longer and wider so they can make the pcb bigger.
The 3090 board must be different then as it has memory on the back?Not sure where they would put them on the back![]()
it is but with 2gb modules they can do a 20gb 3080ti and only use one side of the board.
if they use both sides it has to be 24gb I think. Then too much like the 3090
Thanks. Just what I expected then. 13% gain if you have a good 2080ti.
great for everybody else to catch up with 2080ti users after 2 years and good to a degree that people with a good oc 2080ti may as well skip this gen and use their overpriced card for another two years.
bad news is that we still don’t really have that 4K card giving consistent 60-120fps unless you are prepared to shell out for a £1500 3090 and even then it’s only going to be 30% faster than a good oc 2080ti.
More like 25 to 30% when the 3080 is overclocked though
It’s dump at overclocking by the sounds of it though. 1-3%More like 25 to 30% when the 3080 is overclocked though
Tear down video was cool
So am I reading correctly that people seem to think that the FE will be a better card to have than the AIBs? or is it much of a muchness?
I’m still half tempted, then sell my good clocking 2080ti (~15%) Nothing to lose really if its as good and the heat wont affect my CPU HSF which apparently it won’t.
Might try tomorrow
Watching now - what on earth with the glue? Hasn't he heard of blu-tak?
Maybe I'm missing something but seems around 10% minimum overclock improvement
the 3080 is 15% faster than a 2080ti OC@320w. 1usmus sums it up wellMore like 25 to 30% when the 3080 is overclocked though
why didnt nvidia just go with 12gb since they can fit 12 on one side, deliberate penny pinching to make the cards obsolete faster.
Yes, you are missing pretty much every review that tried to OC. It's not even 10% AT BEST. Minimum is more like 3%.Maybe I'm missing something but seems around 10% minimum overclock improvement
15% faster in what benchmark? show me some frames.the 3080 is 15% faster than a 2080ti OC@320w. 1usmus sums it up well
