- 27 Mar 2013
I can't believe he knicked the grill tooThe check in report which i mentioned details the damage when it was returned to thrify.
4 months after the hire and 1,700 miles later, the assessor reports shows the following damage ;
NATURE OF INCIDENT
The vehicle has suffered light to moderate collision/impact damage to the front, light to moderate collision/impact to
the front and light damage to both sides LH and RH.
REPAIR SCHEDULE
New parts required:-Front Bumper, L/F Bumper Air Guide, R/F Bumper Air Guide, Frt Bumper Support, Screw,
Engine S-Absorb, Front Impact Damper, Front Grille, Frt Bumper Sensor, Front Lwr Air Flaps, Rear Bumper Cover,
L/R Bumper Guide, R/R Bumper Guide, Rr Bumper Adapter, L/Nut, R/Nut, Rear Bumper Support, Rear Badge
Repairable parts:-Repair Left Rear Damage, Repair Right Rear Damage, Repair L/R Door, Repair R/R Door, Repair
Outer Rear Panel, Repair Bootlid, Repair L/R Side Panel
Repaint only parts:-Front Bumper New Part Paint K1r, Rear Bumper Cover New Part Paint K1r, Bonnet Repair
Painting <50%, L/R Door Repair Painting <50%, R/R Door Repair Painting <50%, Outer Rear Panel Repair Painting
<50%, Bootlid Repair Painting <50%, L/R Side Panel Repair Painting <50%, Right Front Door Surface Paint, Screen
Mask Rear Surface Paint, Pre-Painting Sundry Materials, Preparation for Pre-Painting
Specialist/Sundry charges:-E.P.A. Charge, Adas Reset, 4 Wheel Alignment, E.P.A. Charge, 4 Wheel Alignment
Remove And Refit parts:-Vehicle Check, Front Bumper Trim, Front Bumper Carrier, Renew Front Bumper Trim,
Add/Work Park Distance Control, Strip And Refit Bonnet, Left Sill Rail, Strip + Retrim L/R Door For Painting, Strip +
Retrim R/F Door For Painting, Right Front Door Trim, Strip + Retrim R/R Door For Painting, Strip And Refit Work L/R
Side Panel, Strip + Retrim For Painting Of The, Bootlid Trim, Bootlid Seal, Add/Work Park Distance Control, Left Front
Wheel
ROADWORTHY STATE
In our opinion this vehicle was not roadworthy at the time of our inspection as a result of the damage sustained in this
incident due to the front damage.
We hope that the foregoing is of assistance and please do not hesitate to contact us should you require anything
further in this matter.
Anyone know what this is?
roll a 20 sided die
