- 24 Mar 2011
- Kent
2.1 gives 4k 120fps and beyond.I don’t even have a hdmi 2.1 tv yet. Is it really beneficial ? I have a Samsung 4K currently. It should do right ?
You'd need a 4k 120hz TV for HDMI 2.1 to be worth the upgrade, personally I'm sticking with my 3440x1440 60hz ultrawide and 1920x1080 60hz monitors until i know what the PS5 will support. Even playing at 1080p, games should be rendered at 4k then downsampled to 1080, which will give better quality than outputting at 1080p.
4k 120hz monitors are rare/expensive at the moment so I may end up with a cheap 4k 60hz monitor to replace my 1080p one.
I'm also holding off on buying the PS5 headphones as there's a chance my Fiio K3 DAC/AMP will work with it, being a USB DAC/AMP - however it doesn't look like it worked on the PS4, only the E10K did... Need reviews of the PS5 headphones too.
