Comparing the PS5 RDNA 2 GPU to the RX 5700 is interesting, it has the same core/render config as the RDNA based 5700. The only difference in the specifications is the clock rate, which has increased from 1725 MHz to 2233Mhz, and the VRAM has increased to 16GB. The TDP is apparently 180w for both GPUs, the PS5 TDP might actually be a bit higher or lower than this (spec from Techpowerup)
Working out a possible RDNA 2 PS5 like desktop GPU:
If we assume adding 4 CUs uses ~40w of power, so 36 + 16 CUs would result in a total of 52 CUs @2233mhz, with a TDP of 340w. This amount is reduced from 45w, which is based on the TDP difference between the 5700 and RX 5700 XT (no difference in clock rate / TMUs to account for here).
Each 4 CUs will result in approx. 10% performance increase. So, +40% for 16 CUs.
This is based on comparisons between the performance of the RX 5700 and RX 5700 XT (36 vs 40 CUs. I reduced this amount from 13% to 10%, to account for differences in the TMUs and clockrate)
There's a 29.4% increase in clockrate from 1725mhz to 2233mhz.
So, around a 69.4% total increase in performance, compared to a RX 5700?
Maybe a little more for IPC improvements?
Hypothesis - The PS5 RDNA 2 GPU seems like a more power efficient RX 5700, which allows for much higher GPU clocks at about the same TDP.
