- 23 Aug 2010
Which cable vendor?
If you are in a rush then there are companies online printing it out for you if you upload the files
Thats good to know as I'm getting impatient waiting for SFF power supplies to come back into stock
Amazing you managed to get a hold of one, most places are so out of stock they dont even do pre-order for itWell I have preordered a EVGA GeForce RTX 3080 FTW3 Ultra Gaming so will be interesting to see how it goes in this case.
Amazing you managed to get a hold of one, most places are so out of stock they dont even do pre-order for itIt says 300 mm in the specs and our case should fit 330 mm, so it should fit, may need to fiddle a bit with cabling depending on what you have in it now.
I'm tempted with the Asus TUF Gaming OC version, which is also 300 mm.
Unlike the MSI GeForce RTX 3090 GAMING X TRIO 24G which is 335 mm.... I wonder if the 330 mm max is true or kind of flexible like the CPU heights![]()
What about those of us who cant make the bracket?
My local library has a free 3d printing service, might be worth checking to see if you do aswell.
Thanks for that! How much would 3d printing cost in general?@Fryan.F There are so many places nowadays it's insane...
Have a look at https://all3dp.com/2/what-s-the-best-3d-printing-service-in-the-uk/
I have used https://www.3dhubs.com myself before, but this was back in Dec 2017/Jan 2018
My own 3D printer should arrive next month, but have never used one before, excited to start using itWould not recommend waiting for me though
Might have to check mine as the cheapest quote so far has been £56
Could do with finding one as I'm getting impatient waiting for SFF psu's to come back into stock. Its the one item stopping me from my buildI wonder if there could be another way of securing an ATX PSU in the case?
MATX mobo and ATX PSU in NR200
From 07:30 it gets interesting - it's in Chinese but you get the gist of it.
