- 22 Aug 2004
Worst bants ever![]()
Check out my orange, banana and apple peel:
To be fair, it isn't the best, there is a bit of orange peeling going on!
Didnt think the orange peel was that bad, to be honest. Nor do I think its that bad in general, and nowhere near as jarring as swil marks and marring...at least with orange peel you can only see it close up, whereas swirl marks can be visible a mile off. And orange peel just gives the paint a textured effect...not desirable, but arguably not horrendously unattractive.
Oh. I've only ever noticed it close up, and even then rarely think much of it.
That's the best thing about it, reminds you of a once unrivalled SUV.I do like the vauxhall frontera colour.
Most aren't that bad. But I've done rattle can jobs on my driveway which end up with less orange peel than some new cars. Mercs are another one I've noticed are pretty bad at times.
I don't know when it started or why, what painting method changed etc? Cars never used to be orange peely.
Water based paints and reduction of all the use of solvents etc is the main reason.
Most likely more reliable too. Frontera's are like cockroaches.
