I just wanted a toy and it’s shaped like a gun that fires lasers! Double win![]()
BuT It IsN'T AcCuRaTe ThOuGh.
Looks a bit like a speed gun, so if you ever have an issue with speeding drivers in your area...
Looks a bit like a speed gun, so if you ever have an issue with speeding drivers in your area...![]()
Who put 20p in Psycho Sonny?
He's solar powered.
Didn't pay full price for them though. Wouldn't do that, he got a deal.He's only using solar panels that the pro's recommend though
These are perfectly fine. When measuring bodies for a fever you're not looking for accuracy, you're just looking for elevated temps. Whether it's 5deg over or 10deg over is irrelevant.
That said, these IR thermometers aren't very accurate with fluids so keep that in mind. I wouldn't be using one for cooking at all tbh, I use them at work for AC temperatures mainly.
I would say 5deg or 10deg over is very very relevant!
Normal range for human body is 36.1 to 37.2. Anything over 38C is considered medically to be a fever. If your dodgy chinese IR thermometer overstates by 2C then normal body is always going to read as been a fever,
Equally if its the other way wrong you might miss a fever,.
39.5C is a high fever and 41C is a very high fever.
Anything over 41C generally means your body is most likely to be suffering from organ failure and you require immediate medical attention which is long before your 42C or 47C which you said is irrelevant lol.
He's solar powered.
No wonder it comes in surges.
My latest purchase. Audioquest DragonFly Red as an upgrade to my MBP, in order to drive my DT1990's. I was impressed by how well it handled my old 990's, still playing with these atm. Liking it a lot so far. Oh, as it's 2020, the obligatory USB-C to A adapter too...
Do you have a comparison how those tiny USB DAC/AMPS compare to actual separate units?
Not personally no, however, I did watch a number of different reviewers on Youtube who did, and nothing they said stood out as a failing for the DragonFly. They seem to be a great little product. From memory, I feel that is has a cleaner sound than my old Asus STX sound card, although I cannot make any comparisons to desktop units.
Ok thanks I have a schiit modi + uber currently which are small but I do like the look of having something a lot smaller and not requiring two plugs!
Picked up the 011D -XL last week and was one of the very fortunate few to nab a 3080!
