- 1 May 2013
- M28
Anyone who has a card, did you get your game codes yet?
Yup, emailed just after the shipping noticeAnyone who has a card, did you get your game codes yet?
Sure, will let you know when I have managed to get it in my machine@WiGgLr , be interested to hear how the fan speeds work for you in afterburner (presuming the GB has fan stop at certain temps) if you get some time please
As I can set 0% but it just will not go under 30% on a profile with my MSi.
Nope, cos where I got the card from isnt in the scheme ..... and TBH the 2 games atm I will be wanting are Watch Dogs Legion and CyberpunkAnyone who has a card, did you get your game codes yet?
Still, I got the card at a fair price so can't complain![]()
Anyone know what idle voltage these cards are showing in afterburner?
GPU voltage, it should be 3rd from bottom.If you can tell me which value you want from GPU-Z I have several saved log files![]()
Ok that's cool then, just had me worried as my last card idled much lower.idles @ 0.718v
It seems to be a display bug in MSI afterburner. It says 31% with these settings, but fans are actually off.@WiGgLr , be interested to hear how the fan speeds work for you in afterburner (presuming the GB has fan stop at certain temps) if you get some time please
This just turned up. Now need to find the time to break my full loop and stick this in. I'll just use the fans for now.
(ref Afterburner 463 beta2)
Aaaand ... nope still cant set a custom profile and keep the stock fan off below certain temps, it forces a minimum of 30%.
I asked the author but he said you cant set below the bios , but the default behavior is fan off at below 60 deg says I.
He replies with a short tempered answer saying he told me what the issue is and locks the thread .... creating these wonderful bits of software must make one very short tempered![]()
