- 6 Jan 2013
- Rollergirl
I'm so jelly, when do did they apear again
05:30 this morning. For about half an hour, and the site was falling over. I can't see it improving by 14:00.
How on earth did you know?05:30 this morning. For about half an hour, and the site was falling over. I can't see it improving by 14:00.
Could someone with a 3080 that runs 3440x1440 try this please.
Install Quake II RTX from Steam (its free)
Change settings to not scale resolution, global illumination high
Ideally screenshoot or write down other settings used
3440x1440 res
Tilde to open console
Timedemo 1
Demo demo 1
What fps?
Interested to see how it stacks up against 2080Ti as it’s the only full path traced game so far I believe.
Overclock it and run the same, how much more fps?
Well I was going to try that in 4k, (or your res if I could work out how) but it tells me there is no such file for demo 1
Sorry my bad ‘demo demo1’Well I was going to try that in 4k, (or your res if I could work out how) but it tells me there is no such file for demo 1
Interested in this as well, i run the same resolution. If its only marginally faster im getting a secondhand 2080ti, cba to wait months on end...Could someone with a 3080 that runs 3440x1440 try this please.
3440x1440 res
Timedemo 1
Demo demo 1
What fps?
Stay up all night smashing F5
I went to bed at 2ish, never would have imagined cards being released at 4:30am!!!Knew I shouldn't have been in bed by 4.30![]()
I actually received the card on monday but have been busy with RL then when I finally got around to installing it some of the builders on the estate decided to chop through a fiber optic cable which left me with out the internet for 2 days so just got around to checking in.
a quick bench run.
Still no filename message .Sorry my bad ‘demo demo1’
edit, beaten to it![]()
No, at stock it scored around 17500 this was with a core +80 mem +900 and fans at 100%Is that bench run @ stock without custom fan profiles?
Still not far off some of the higher specced cards like the evga ftw3 which was only about 200 points higher with a much higher power limit.
I got mine today. I only had time to put mine into my machine and do a run at stock on timespy in my lunch break today - I got 17394 graphics score totally stock. Fans didn't start kicking in until like 65 degrees or something lol. I think I can do something decent with this so I'm relatively happy as a first impression.
Did you guys notice the spatulas in the hardware unboxed review? That cracked me up.timedemo 1
demo demo1
Should look like this. I get 42fps on 3440 x 1440.
I highly doubt the 3080 is capable of "fully path traced games at 4k 60fps" as leather jacked 50 spatula man stated. Also bearing in mind Quake II RTX is a full path traced game but a very old game
We are probably two or three Nvidia generations off fully path traced modern games that run 4k 60fps.
It will be interesting to see what sort of PS5 path tracing game optimisation is used to maintain either 60 or 30fps. Watching some trailers for PS5 games there are even parts where you see it stutter / slow right down to maybe 15fps. Render resolution scaling would certainly help as it works very well in Quake II RTX
