- 25 Nov 2011
- The KOP
You know its bad when even Jay is talking about it. AMD this is your chance...
i think you've mixed that up if the aib cards have 6 black capacitors on the back they are the ones that are falling over at 2ghz+ from the picture in the link you posted the strixx has 6 banks of the more expensive capacitors which are need to stop cross talk and interference, thus allowing more sustained higher clocks
what you want (the asus strix 3080)
vs what you want to avoid at all costs really, unless you plan to not overclock and even underclock (this is the zotac trinity rtx 3080 card)
On the Asus website link I posted the image on there shows the 6 cheap capacitors.
The larger tantalum are more expensive
Repeat ad nauseum
Looks more like the one on the ASUS website is a render and not an actual cardSo I guess that means the Strix 3080 got the cheaper variants and the 3090 has the more expensive ones?
Fine, the more reliable capacitors then, if the theory is correct.
The game isn't even out until the end of OctoberAnyone know how to claim these free games with the 3000 series cards? Are codes sent via email after a few days like before?
Errr reliable capacitor?
This is the way.
Hi all,
Recently there has been some discussion about the EVGA GeForce RTX 3080 series.
During our mass production QC testing we discovered a full 6 POSCAPs solution cannot pass the real world applications testing. It took almost a week of R&D effort to find the cause and reduce the POSCAPs to 4 and add 20 MLCC caps prior to shipping production boards, this is why the EVGA GeForce RTX 3080 FTW3 series was delayed at launch. There were no 6 POSCAP production EVGA GeForce RTX 3080 FTW3 boards shipped.
But, due to the time crunch, some of the reviewers were sent a pre-production version with 6 POSCAP’s, we are working with those reviewers directly to replace their boards with production versions.
EVGA GeForce RTX 3080 XC3 series with 5 POSCAPs + 10 MLCC solution is matched with the XC3 spec without issues.
Also note that we have updated the product pictures at EVGA.com to reflect the production components that shipped to gamers and enthusiasts since day 1 of product launch.
Once you receive the card you can compare for yourself, EVGA stands behind its products!
Thanks
EVGA
Kudos to Igor
