Lego Eagle 5 anyone?
https://ideas.lego.com/content/project/link/6a21cb1c-e42a-4ac0-8cce-273e11b76ca6
Sadly mine isn’t much better. The lime green even on some of the smaller pieces isn’t a great match and I haven’t even got to the bodywork yet.Thanks for the pictures. Blimey thats quite some difference....
I actually couldnt find any articles about the discolouration, is the above your own Sian? or from a website?
From all the comments on lego etc nope.Shame. Thanks for coming back eventually MissChief!
Does Lego acknowledge this problem I wonder?Would they do anything about it in terms of compensation for example?
Exactly.From all the comments on lego etc nope.
It's terrible really.
Id really like the set. But I'm not paying for that level of quality
Took advantage of the JL 20% to finally order the UCS Falcon and UCS ISD. No idea where I will put them yet.
After moving in Feb I have to rebuild all my models. Going to have UCS Red 5, UCS Tie, UCS SSD, original UCS Falcon plus the new ones when they arrive.
Going to try and get my 11 year old involved on the rebuild as some quality time. Hopefully we don’t fall out doing it!
I think he should put all the pieces from the models in one box, ultra super hard modeI believe you win at Dading
No, that's just what they cost. The Falcon one I got was 100+.
Your other choice is to take those measurements and go to a perspex manufacturer and put it together yourself
