DLSS is great, but it surely has a finite lifespan? All the new cards will do native 4K easily and the generations that follow will do 8K too. Surely there will be a time when it’s simply no longer needed and economically worth coding into the game?
I must admit, even though my 2070S can handle ultra SOTTR at 1440p to an acceptable FPS level, I still think with DLSS, it looks better and while obviously running better than native 1440p. I think it takes my average FPS from 53 to 68 FPS.When looking at a bunch of the Control comparisons, tons of 2.0 upscaled 1440p shots look significantly better than native 4k. I'd still opt for 4k DLSS than 4k native in Control.
Perhaps the future will just be AI based fidelity enhancements.
True if you want minimum 60fps. Kind of makes a mockery of the graphics card industry when you consider what the new consoles can do for under £500.It'll be ages before any card can do native 4k with ray tracing though.
One thing I have noticed about Ray Tracing on the 3XXX cards is it is no where near as big an improvement over the 2XXX cards as some of the outrageous claims that were made before the Ampere launch.
A 3090 is about 35% faster in Ray Tracing than a 2080 Ti/RTX Titan on the Port Royal bench, not bad but no where near the X4 that some were predicting.
That's dlss 1.0, it should look much better if you disable it!Been playing Battlefield 5 4k RTX ultra with DLSS on a HDR1000 monitor - totally glorious imo. My first taste of RTX.
How did you calculate that?
I predicted at least double the performance from a few year ago and ended up a little disappointed in that regard. Wanted them to be powerful enough so turning RT did not tank performance so much.One thing I have noticed about Ray Tracing on the 3XXX cards is it is no where near as big an improvement over the 2XXX cards as some of the outrageous claims that were made before the Ampere launch.
If hopper ends up an MCM design like rumoured then I think that will see a big leap in RT performance.
That said I do think as new games start coming out we will see the gap between Turding and Ampere get bigger.
Yeah. My expectations of something better was because I expected them to use more die area for it and increase the number of cores quite a bit more. Still, can’t complain too much. Better than 2080Ti for half the priceIt's pretty much following the same history as Tesselation, exactly as I've been predicting for the last year.
Tesselation v1 (AMD 5870): Looks cool, terrible performance
Ray Tracing v1 (Nvidia RTX2080ti): Looks cool, terrible performance
Tesselation v2 (AMD 6970): Much better performance but still a significant hit to framerate.
Ray Tracing v2 (Nvidia RTX3090): Much better performance but still a significant hit to framerate.
Tesselation v3 (AMD 7970): Little to no performance hit anymore.
Ray Tracing v3 (Nvidia RTX4090): ???
Yes one reason I'm not upgrading, besides being skint! Third gen on I think ray tracing will start to take off. Once I can do similar or better FPS to my 5700XT at 1440p with RT on I'll jump.
Now let’s see what AMD have to bring to the table.Now we have the 30 series testing done, it would appear Ampere has fallen a bit short. Like you mention it should be there next gen, just disappointing they were not honest but if Jensen didnt beguile you it would be another Turing flop (Turing - mainly overpriced, people could have stomached the RTX if prices were lower) so they need to shift the units again this gen, albeit power hungry too.
