The Ampere RTX 3080 Owners Thread
Man of Honour
OP
21 May 2012
Dalek flagship
Just landed.
Welcome and on TROH.:)
The Roll of Honour.
Date 29/09/2020, Make NVidia FE, IT Troll, Link
Date 26/09/2020, Make Asus TUF, Sparx, Link
Date 25/09/2020, Make Palit GamingPro, Kungfudave, Link
Date 25/09/2020, Make Asus TUF, FlyingFish, Link
Date 25/09/2020, Make NVidia FE, hideki, Link
Date 24/09/2020, Make MSI Gaming X Trio, jabski, Link
Date 24/09/2020, Make Palit GamingPro, Spikey, Link
Date 24/09/2020, Make MSI Ventus, XeNoNF50, Link
Date 24/09/2020, Make MSI Gaming X Trio, Gripen90, Link
Date 24/09/2020, Make Palit GamingPro, no_1_dave, Link
Date 24/09/2020, Make MSI Ventus, Joxeon, Link
Date 22/09/2020, Make Gigabyte Gaming, WiGgLr, Link
Date 22/09/2020, Make Palit GamingPro, Ace Modder, Link
Date 22/09/2020, Make Zotac Trinity, Ace Modder, Link
Date 22/09/2020, Make Zotac Trinity, Shockwave, Link
Date 21/09/2020, Make Zotac Trinity, InkZ, Link
Date 19/09/2020, Make Palit GamingPro, mingey, Link
Date 19/09/2020, Make Zotac Trinity, hyperseven, Link
Date 18/09/2020, Make MSI Gaming X Trio, Vogon, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3080
22 May 2010
Minibotpc
I tried DDU, but nothing. Also uninstalling anything that might be controlling the fans. I've emailed Palit support about it - will let you know if I hear back.
This is the reply i got from Palit CS:
I believe the Card going over 60W is whats causing the annoyance... dunno why they didnt just have the 150W to begin with?
22 May 2010
Minibotpc
Ah, so seems like the firmware update will make it come on less frequently? Good to know!
Yes it seems so, how well it works we won't know till we try it. I'll keep an eye out on the bios update and test it when its released.
Edit: Actually maybe not as im slapping a waterblock on it shortly
11 Mar 2008
Norn Iron
People who have started receiving their Founders Editions did you all manage to bag on eon release day and they are just coming now, or did you just get lucky and pick one up from the site when the "in stock" label showed?
1 May 2013
M28
Still can't get my Zotac to crash.
It's running quite happy with 50/500 oc and boosts to 2055.
Tomorrow is last day under CCR for a no quibble refund and still have a day one TUF OC ordered at a place near me.
Do I believe the internet hype and ditch this card?
Have played about 18h of Assassins Creed Odyssey, few hours of FH4 and countless benchmarks and the thing just won't die. Anything else I try to make this fall over to sway my decision?
24 May 2015
Can someone with a TUF do me a huge favour and measure how much the backplate adds above the pcb. So that would be top of the pcb to top of the backplate of the card. Preferably at the mounting end. My board has an IO block quite close to my current card which doesn't have a backplate. It should be fine as I have about 7mm clearance currently and from a review, the guy's ruler shows about 4mm. @FlyingFish @Sparx
Thanks
Man of Honour
OP
21 May 2012
Dalek flagship
Old vs new. Just received this morning, also.
Delivered this morning. :)
The Roll of Honour.
Date 29/09/2020, Make NVidia FE, Captain, Link
Date 29/09/2020, Make NVidia FE, LonelyDriver, Link
14 Nov 2002
Dont worry, if it works fine and you are happy keep it, the internutz made a storm in a D cup ;)
On the other hand, The Asus is probably the best cooled card out there, so if thats important keep that one and return the other.
15 Jun 2005
Edinburgh
For the FE owners, has anyone been able to source a 12pin power connector for their PSU instead of using the adapter?
I hovered over the EVGA cable but then came to my senses; $40 is a joke. Also, in my case it is a pain to swap the modular cables so sticking with standard cables seems a better idea until the day all cards use the new connector.
