Try entering Easy Mode (BIOS/UEFI) and set the XMP - it will be disabled by default. Then F10 etc...@Plec may I ask what to do regarding setting memory xmp?
Great, you're all set for now. You really have a quality setup (all of it - like the speakers) - and all looks very premium on your desk.@Plec done thumbs up
Very brief (will pop back later):Would the autos 360 fit at the top of my case? It seems as there’s only enough slots for 2 fan fixings?
I’ll have a look at the other, much appreciated![]()
I know@Plec those are ryzen vids.. 20 core intel runs a lot hotter :/
@Plec @orbitalwalsh Could I potentially run the 360 fans at the front of the case instead of the sp120 fans? And put 2 sp120 fans at the top of the case?
if I’m best sticking with the dh15 noctua then “thumbs up”
Yes you could - but your wallet will feel the difference more than your CPU - but it should cool slightly better with the right curve and have the overall look you're after.@Plec @orbitalwalsh Could I potentially run the 360 fans at the front of the case instead of the sp120 fans? And put 2 sp120 fans at the top of the case?
No, you don't have to lose the RGB.At the same time would I lose the rgb? I like the rgb fans at th front....or could I just change the 360 fans to the sp120 rgb ones?
LOL - that was an example - you don't mess about.thanks very much, once again.
They're hard to come by - unlikely he got the Elite.Which AIO, new Corsair comes with Corsair commander pro unit.
