- 12 Sep 2014
Strong enough to blow components off your board![]()
And sound like a hairdryer while it does it!
I don’t know. I own a x570 and for me it’s not a problem and has never been a problem. I have a custom loop with plenty of addition airflow and have yet to hear the fan. If it does break which it could do, I’ll just slap a water block on it.Exactly. Let's face it, load's on here have B Die ram running at over 4.5v Anyone that does should have active cooling on the ram..........................that active cooling will be at least twice as loud as any X570 chipset fan, assuming the chipset fan was running in the first place.
If your fan can't push a full can of soda is it even cooling your system?
Lol..............proper fans. Still got 4 of them for benching...............they just blow any moisture away instantly![]()
People are entitled to buy what they want and think what they want but as it stands the x570 is the top of the stack for Zen 2 and the upcoming zen 3.
Yeah I really don't want to see that in my case for this next build.I remember those days massive all copper heatsink with a silly Delta cooling it.
Got a modding project in the works centered around the 9500 LEDCopper Zalman fan shaped heatsinks were beautiful
Thermaltake DuOrb GPU cooler to match (although it might not get used).Well if they don't even mention it then I'll take it that the 8 core will be better for games / latency stuff.They'll probably highlight the fact you can run it in Game Mode with one whole CCD disabled, and the other core boosts to much higher clocks as it is better binned to make up the short fall, maybe even 5GHz.![]()
Are AIO CPU coolers a) effective and b) easy enough to install?
I have no intention of doing a full loop. Too much like real work![]()
they don't perform as well as an air cooler in terms of raw cooling performance.
Uh.... are you sure about that? Using liquid to pumping the heat away to a huge radiator sure seems like to would have a decent amount of "raw cooling performance"
Top air coolers (usually meaning Noctua D15) outperform some AIOs.Yes I'm sure, look at any benchmark the top air coolers outperform the top AIO's
Just go look at benchmarks. Air coolers like the Noctua NH-D15 are in practical terms as good as (in the same performance range) many of the top AIO's, without the potentially PC-damaging downsides.Uh.... are you sure about that? Using liquid to pumping the heat away to a huge radiator sure seems like to would have a decent amount of "raw cooling performance"
Not good. Means Zen 3 samples are not going around. Means it will take longer for reviews to appear and even longer for general availability2 days to go and not much is leaked.
seems security is tighter than ever.
good
