Permabanned
- 21 Sep 2020
LOL !!!!!!An OK amount.
I’m not defending the store. I would speak in the same way about a competitor, I’m personally not an exclusive shopper.
The newbies sure not able to accept that if you don’t hear, there isn’t an update. They sure are blind in their “needy baby greedy baby” “innit”
(OCUK 4kyf, ain’t gon shop no where else)
Golden week is the 2nd - 8th, right?
Any info on Strix OC 3080?
I’m 216 in Queue so not sure when I’m getting mine, hopefully before Christmas or Cyber
1st to the 7th, back to work tomorrow.
TimeAndDate would disagree. https://www.timeanddate.com/holidays/china/+1st to the 7th, back to work tomorrow.
An OK amount.
Emailed to us.Where are you all getting your que number from?
Email from overclockers.Where are you all getting your que number from?
They are wrong, I'm afraid it's that simple !TimeAndDate would disagree. https://www.timeanddate.com/holidays/china/+
Top answer!! Is that a bigger OK or a smaller OK though? Only we all thought that OK was 50-100 but turns out be 47, and small was 10-50 which turns out to be 7... anyone confused yet??![]()
Emailed to us.
There will be another email hopefully in the next 2 days or so as the last one was about 5 days ago.
Yes, but wasn’t there supposed to be a tiny or something for <10? That’s what we got with the TUF OC’s. I guess OK means ‘almost average’ then. Fingers crossed for some ‘pretty goods’ and ‘half decents’ coming soonLess than 50 is small, more than 50 is average, more than 100 is big and more than 1000 is a dream.
150 boxes? No you mean up to 3000 in a 40ft container, that's if your talking about actual size of each individual retail boxes150 boxes will fit in one shipping container, right? If you think that they will get 20 containers in 3 months, think twice bro.
